1 - 8 of 8 Posts
Hks ssqv4 bov
I have a bk2 2.0t. With injen intake and hks bov. When I rev my car there’s no “discharge “ wile not moving. but everything works fine I reach full boost when driving I can hear it spool when getting over 4500 rpm. and I have the purple fin in but I don’t get the “chirp “sound whenever I’m driving and gas on the pedal. Any help would be great. No codes or anything This photo is before my intake and I have no recirculating line.
If you have an automatic, BOV won't open while not moving. Like reving while in park or nuetral does nothing. Not sure why you're not hearing it open when driving though.
IG: jasonlikedthis
Did you hook up your vacuum back to the original port?
Discussion Starter #4
I have a 6 speed rspec.
And yes but I’m using the original hose. Would I need to upgrade the lines to a 3/16 and 3/8 ?
This is my setup
It tees off the manifold
if you're in a pinch and want to make things simpler, you can disconnect the green/white check valve and plug it into the green side nipple on the manifold.
With how it seems like you want to plumb it, that check valve/vacuum tank/ bov solenoid isn't doing much of anything anyways.
1 - 8 of 8 Posts
