2010 GC 3.8 Track 6MT
Just picked up a 2010 3.8 Track and don't have the owners manual yet. Searched the forum for homelink but didn't find my issue discussed.
I can program the homelink buttons on my mirror, but only the last one I programmed works. I.e., if I program the left garage door on button 1 and the right garage door on button 2, the last button I programmed is the only one that works. The first button just shows red.
The first button works fine until I programm the 2nd button. I can't imagine this is how it's supposed to work, else why give me the option to have 3 door buttons?
What have I overlooked here?
Bill
found my old 10 manual. no attachments allowed...
Integrated HomeLink® Wireless Control
System
The HomeLink® Wireless Control
System provides a convenient way to
replace up to three hand-held radio-frequency
(RF) transmitters with a single
built-in device. This innovative feature will
learn the radio frequency codes of most
current transmitters to operate devices
such as gate operators, garage door
openers, entry door locks, security systems,
even home lighting. Both standard
and rolling code-equipped transmitters
can be programmed by following the outlined
procedures. Additional HomeLink®
information can be found at: www.homelink.
com or by calling 1-800-355-3515.
Retain the original transmitter of the RF
device you are programming for use in
other vehicles as well as for future
HomeLink® programming. It is also suggested
that upon the sale of the vehicle,
the programmed HomeLink® buttons be
erased for security purposes.
Programming HomeLink®
✽ NOTICE
• When programming a garage door
opener, it is advised to park the vehicle
outside of the garage.
• It is recommended that a new battery
be placed in the hand-held transmitter
of the device being programmed to
HomeLink® for quicker training and
accurate transmission of the radiofrequency
signal.
• Some vehicles may require the ignition
switch to be turned to the second
(or "accessories") position for programming
and/or operation of
HomeLink.
• In the event that there are still programming
difficulties or questions
after following the programming steps
listed below, contact HomeLink® at:
HomeLink or 1-800-355-
3515.
Standard programming
To train most devices, follow these
instructions:
1. For first-time programming, press and
hold the two outside buttons,
HomeLink® Channel 1 and Channel 3
Buttons, until the indicator light begins
to flash (after 20 seconds). Release
both buttons. Do not hold the buttons
for longer than 30 seconds.
2. Position the end of your hand-held
transmitter 1-3 inches (2-8 cm) away
from the HomeLink® buttons while
keeping the indicator light in view.
3. Simultaneously press and hold both
the HomeLink® and hand-held transmitter
button. DO NOT release the buttons
until step 4 has been completed.
4. While continuing to hold the buttons
the red Indicator Status LED will flash
slowly and then rapidly after
HomeLink® successfully trains to the
frequency signal from the hand-held
transmitter. Release both buttons.
5. Press and hold the just-trained
HomeLink® button and observe the red
Status Indicator LED. If the indicator
light stays on constantly, programming
is complete and your device should
activate when the HomeLink® button is
pressed and released.
6. To program the remaining two
HomeLink® buttons, follow steps 2
through 5.
Rolling code programming
Rolling code devices which are "codeprotected"
and manufactured after 1996
may be determined by the following:
• Reference the device owner's manual
for verification.
• The handheld transmitter appears to
program the HomeLink® Universal
Transceiver but does not activate the
device.
• Press and hold the trained HomeLink
button. The device has the rolling code
feature if the indicator light flashes rapidly
and then turns solid after 2 seconds.
To train rolling code devices, follow these
instructions:
1. At the garage door opener receiver
(motor-head unit) in the garage, locate
the "learn" or "smart" button. This can
usually be found where the hanging
antenna wire is attached to the motorhead
unit. Exact location and color of
the button may vary by garage door
opener brand.
If there is difficulty locating the training
button, reference the device owner's
manual or please visit our Web site at
HomeLink.
2. Firmly press and release the "learn" or
"smart" button (which activates the
"training light").
. NOTICE
There are 30 seconds in which to initiate
step3.
3. Return to the vehicle and firmly press,
hold for two seconds and then release
the desired HomeLinkR button. Repeat
the "press/hold/release" sequence a
second time to complete the programming.
(Some devices may require you
to repeat this sequence a third time to
complete the programming.)
4. Press and hold the just-trained
HomeLinkR button and observe the red
activate.
5. To program the remaining two
HomeLinkR buttons, follow either steps
1 through 4 above for other Rolling
Code devices or steps 2 through 5 in
Standard Programming for standard
devices.
Gate operator & Canadian programming
During programming, your handheld
transmitter may automatically stop transmitting.
Continue to press the Integrated
HomeLinkR Wireless Control System button
(note steps 2 through 4 in the
Standard Programming portion of this
document) while you press and re-press
("cycle") your handheld transmitter every
two seconds until the frequency signal
has been learned. The indicator light will
flash slowly and then rapidly after several
seconds upon successful training.
Operating HomeLinkR
To operate, simply press and release the
programmed HomeLinkR button.
Activation will now occur for the trained
device (i.e. garage door opener, gate
operator, security system, entry door
lock, home/office lighting, etc.). For convenience,
the hand-held transmitter of
the device may also be used at any time.
Reprogramming a single HomeLinkR
button
To program a new device to a previously
trained HomeLinkR button, follow these
steps:
1. Press and hold the desired HomeLinkR
button. Do NOT release until step 4
has been completed.
2. When the indicator light begins to flash
slowly (after 20 seconds), position the
handheld transmitter 1 to 3 inches
away from the HomeLinkR surface.
3. Press and hold the handheld transmitter
button. The HomeLinkR indicator
light will flash, first slowly and then rapidly.
4. When the indicator light begins to flash
rapidly, release both buttons.
is complete and your new device
should activate.
Erasing HomeLink® buttons
Individual buttons cannot be erased.
However, to erase all three programmed
buttons:
1. Press and hold the two outer
HomeLink® buttons until the indicator
light begins to flash-after 20 seconds.
2. Release both buttons. Do not hold for
The Integrated HomeLink® Wireless
Control System is now in the training
(learn) mode and can be programmed at
any time following the appropriate steps
in the Programming sections above.
Thanks for posting that. It looks very much like what I did, just guessing. I'll print that out and try it later today when I get home and see if I have any better luck.
i'd try the Erase function.
Not sure I follow. When I program the #1 button for the left side door, it works fine. When I program the #2 button for the right side door, that also works fine, but the #1 button no longer drives the left side door. And vice versa if I program the #2 button first.
Bill
the last part of the instructions tells how to erase all programming.
it may initialize whatever condition you've got.
if you're doing the first time procedure every time, you're doing the Erase every time.
for the second & third buttons, just do the individual button.
