1 - 7 of 7 Posts
the past few days every time i hit a bump or a rough road my hood seems to almost bounce up and down and make an annoying squeaky sound.
has this happened to anyone else?
is there an easy fix? the only thing i have thought of would be putting some kind of foam under the outside of my hood so it puts pressure on it.
I have also noticed a squeaky/rattle sometimes when the car is idling. But of course when i took it by the dealership it didnt rattle. Go figure.
The black plastic stops at the front can be screwed up or down to adjust tension against the hood.
ahh i c! thanks
Mine use to do that. Its the rubber rubbing on metal. I tried to adjust it and still happened. I hated how it sounded like a belt was going out sometimes. I just bought these little felt cloth things you put on the bottom of chair legs on there. Problem solved.
1 - 7 of 7 Posts
