1 - 10 of 10 Posts
Parabolica Blue 2.0T :)
So guys, I want to adjust the horizontal alignment of the projector (non-hid) headlights on the 2013 model... I looked at the manual and could not find it anywhere and searched these forums to only find information about the old headlights, which I think are a bit different? (Someone correct me if I'm wrong).
Anybody know how to do it? Is it one of these two: (green circle/ red circle) or neither.
Much appreciated!
The red one you circled is a bulb. Ye horizontal adjustment is right next to the red circle (silver metal thing with a Phillips slot in it)
Yes. Blue circle. It must be adjusted with the headlight out.
It sucks since the kdm headlights don't have the corner bulb (red circle) so they install a guide (similar to the height adjustment) so you can adjust with a Philips screwdriver with the headlight on the car
Is the green circle for vertical adjustment
Thanks for the info mine came from the factory with the driver side a little higher
On my 2010 the up/down and horizontal is different depending on which side you are on. The raised directional arrows are the same though on both headlights.
Do the 2013 headlights have arrows opposite each other between the two headlights?
1 - 10 of 10 Posts
