1 - 10 of 10 Posts
Hello everyone
i plan this christmas time to paint blackout the headlight and in the same time i want to install an Halo kit switchback from morimoto. i have original HID headlight and wondering how to plug them to the DRL (white light) and HID (yellow light).
thank you for the informations pictures and DIY
Hello my Friend
do you have the electrical diagram or which color of wire i need to plug them?
Best Regards
If you are going to open the headlights I would make the connections internally.
Here are the pinouts of the connectors and the Wire Diagram. Looks to be pin 1 and 5 on each headlight. Colors are on the WD but the don't always match the car I've found so go by the pin numbers.
Wow thanks for the information i will check that in the next week, i guest it's the same diagram for HID and normal headlight.
i will try to keep the wire inside the headlight.
thank you very much
Ciao
Hello last question
the Halo works on the 12volts but i don't see on the drawing what is the voltage at the pine 1 and 5.
do you know it?
Best Regards
Hello Raspberry
i want to plug the halo this week end, just to be sure the side marker is not 1 @ 5.
do you have the number?
another question in automatic mode (headlight) did the side marker are open with the DRL?
Best Regards and thanks a lot for your help
Ciao
The pins may be different depending on year, model and accessories.
You need to get a volt meter and see what they are by probing the plug for power and ground.
1 - 10 of 10 Posts
