1 - 20 of 119 Posts
www.diodedynamics.com
Hyundai Genesis Coupe License Plate LEDs! Plug & Play! Several Bulb Models Available!
License plate bulbs are used to illuminate the rear license plate on your GenCoupe. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Genesis Coupe!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Genesis Coupe looks at night.
Brightness:
Diode Dynamics offers several bulb models so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Genesis Coupe).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
CLICK HERE TO ORDER
Or, upgrade all of your interior bulbs:
Diode Dynamics Full LED Conversion Kits!
CLICK HERE TO ORDER
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Customer Submitted Photos:
Bump for a dealer who's a pleasure to work with and delivers great products
Speaking of, if anyone's interested, I have a set of DD stage 3 Blue license plate bulbs I'll be putting up in the classifieds soon for like $10. They work fine, just got bored with blue and ordered the white ones last night. Only had the Blue ones in for 4 months or so without any issues.
Improving WHP
I cant for the life of me figure out how to place these. :gc-wmscared0016:
Whats the cost for
The licnese plate lights, Dome lights ?
in White LED
Improving WHP
Sorry last question.
Difference in stages?
Is that how much output so you receive a different color ?
Nevermind, its brightness... I finially learned how to read.
To anyone on the edge about getting these, let me say a few things..
-I dont recommend red if you actually need the light because even the stage 3 kit isnt very bright, but it does look nice.
-I did have issues with my order, i received a defective glove box light, it only had one of the metal prongs vs the two its supposed to have, and in my kit i didnt receive my trunk light.
-With that being sad, i contacted diode dynamics once i found the issues and they responded same day, offering to send out replacement parts.
Overall i would definitely say that i enjoyed the experience shopping with them, although there were issues i am very understandable so that didnt detract from my experience, plus they are very customer friendly and immediately offered to fix any issues i had, highly recommend the LED kit, and Diode Dynamics.
1 - 20 of 119 Posts
