Short Throw Shifter DIY
Hyundai Genesis Coupe 2010
So in order to make installing Short Shifters even easier, we have decided to post up a DIY here on the forums so that you can all see how easy it is to install one yourself!
Begin the installation by parking on a flat surface, as you will have to engage and disengage the hand brake and shift from gears to neutral. If you cannot do so and are obliged to install the short shifter on a slightly inclined surface, place wooden blocks in front or behind the wheels to prevent the car from moving while you’re working.
Estimated Installation Time: 60 minutes
Tools required:
- 10 mm socket
- 19 mm socket (long is preferred)
- 7/16 socket
- 19 mm wrench
- 7/16 wrench
- Ratchet
- 3” extension
- Long screw driver
- A lift or a jack and jack stands.
- All purpose automotive grease (white lithium based grease is preferred)
1. Working inside the car, unsnap the shift boot from around the shift knob and remove the shift knob by turning it counter-clockwise and put it in a safe place.
2. Putting your hand inside the shift boot, pull the plastic console up.
3. If needs be, undo the heated seats plugs and put the console part in a safe place.
Push the rubber boot down.
4. Jack the car up and undo the 2 19 mm nuts holding the resonator with the rear part of the exhaust piping. Once this is done, pull both part of the exhaust apart, leaving all exhaust supports in place.
5. Locate the 6 10 mm bolts holding the heatshield that is right over the resonator and remove them.
6. Now slide the heatshield toward the driver’s side with somebody holding the exhaust piping out of the way while you do this.
7. You should now clearly see the shifter. You need to remove a small metal clip that holds the pin inside the rod. Do this by using a long screw driver and pushing it out. Keep this clip if you ever want to re-install the stock shifter eventually.
8. Slide the pin out of the shifter and rod assembly.
9. Undo the two 10 mm bolts holding the silver ring and put these in a safe place as you will need them later.
10. Pull the shifter down to have access to the black plastic ring around the pivot point and remove both o-rings. Slide the plastic ring down and take it off the shifter completely.
11. Go back inside the car and remove the shifter. It will go only if you tilt it to the side so that the larger bottom part clears the floor.
Insert your short shifter through the rubber boot and install the rubber boot around the larger part of the short shifter.
12. Go back under the car and apply grease to the pivot point.
13. Re-install the plastic cup over the short shifter. The flat o-ring goes on top, then slide the plastic cup around the pivot point and install both o-ring on the plastic up.
14. Put both 10 mm bolts with the silver ring in place, locking the shifter in place.
15. Place the supplied bushings inside the fork and slide the short shifter in between them. You can use a wrench to move the shifter to help you inser it between the bushings.
16. Align hole in the bushings with the bearings of the shifter. Place both washers on each side of the fork and tighten the bolt and nut using a 7/16 wrench and socket.
17. Re-install everything in reverse order from step 6 to 1.
THAT'S IT!! Now all you have to do is ENJOY it every time you SHIFT!
If you have any other questions or concerns you can post in this thread or send us a PM and we will be more than happy to help you out with your Short Shifter install!
Jordan
Team TWM Performance
Tools required:
- 10 mm socket
- 7/16 socket
- 19 mm wrench
- 7/16 wrench
- Ratchet
- 3” extension
- Long screw driver
Jordan
