1 - 3 of 3 Posts
I currently have a 2012 3.8 and need to find someone who has the experience to fully build and turbo a 3.8. Id like to get somewhere around the 700-900 hp range. From sleeves to forged parts whatever it needs I can get I just need someone to do it and to give a ballpark estimate of the cost. If you know someone in the NJ/PA/NY area lmk. Not looking for people to tell me why I shouldn't or why they think its a waste of money/time. Thanks.
you'll want new internals, mainly to lower compression to 9:1, then higher lift cams. both of which are going to have to be custom. This will allow it to take more boost and more timing. Those are the main things that come to my mind.
A long while ago, there was a shop that made one to get to 1000hp. there is a video of it on youtube. Might want to contact that shop. From remembering the track run from that video, you'll want to get a 1.5 or 2 way LSD diff. At that high HP range, the stock torsen lsd isn't enough. The diff is likely not to break, but it will make the rear wiggle on hard runs.
Edit: found the video. I have the video start at where the driver is explaining what's going on with the diff.
1 - 3 of 3 Posts
