1 - 11 of 11 Posts
The SFGenKid
Time to start thinking about injectors.been thinking about the dw 550cc injectors and saw that people were talking about evo x injectors. Do they really fit and work as well as the dw injectors? Thoughts?
Sex Machine
Get the DW 500cc because BR already has a tune for them that works good. I believe with the Evo X injectors, u'll need the CMD to tune but I have no idea. Either way u just can't throw injectors in ur car without a custom tune.
FUNCTION OVER FORM
But with the $$ you save with the Evo injectors, you can pretty much afford a custom tune on a dyno if you already have tuning equipment. ;) Just something to think about.
The EVOX injectors are awesome, i have flow tested 3 sets of them and i have
to say that they are a quality injector and are a perfect replacement as far as
size(o-ring to o-ring) and they flow very well.
You can probably work with beyond redline to get a custom PA tune for them or
use a CMD to tune for them, you would probably have to send the EVOX
injectors to Beyond Redline for them to put them in a car and tune for them but
that should be something they can do easily.
Outside of the EVOX injectors i found some nice injectors that i have been
running for about 4000 miles now with no complaints and they flow better than
the DW injectors and are less expensive, and likely a higher quality if you ask
me.
see the link below for my research
http://www.gencoupe.com/2-0t/50564-injector-teaser.html
Sex Machine
True but only if u have the equipment
The SFGenKid
Ok cool I've had some bad.experiencees with bosh in the past years so I'm iffy on them. And.the evox injectors look pretty promising so that's why I'm masking
EVOX injectors are technically a bosch injector, because they use a patented
bosch design and circuit but are made by Mitsubishi
Gooood! GOOOOOD!
I'll be offering 660cc injectors soon. :) Price pending.
The SFGenKid
Discussion Starter · #11 ·
What kind of 660cc injectors;
1 - 11 of 11 Posts
