1 - 3 of 3 Posts
Okay, I put on an injen airtake and everything went great. When looking at the finished product I noticed that one of the hoses had a hole in it now. Probably from me moving it around.. it was very stiff. It says vac pipe and an arrow on it. It just so happens that there's a hose that came with the injen airtake that is the same size as the broken hose. Is this what it is for? I reread the directions like 5 times and it says nothing about this hose. Idk what else it would be for.
IG: jasonlikedthis
The only hose I can think of that you're talking about is the recirc hose. If that's the case then you technically don't need it, but you will need to cap off the open ends.
I ended up calling injen and found out that it's an extra hose that wasn't suppose to be in there. It doesn't go to anything for my car. Thanks though.
1 - 3 of 3 Posts
