I just got some led stage 1 interior lights from Diode Dynamics, every light was going fine until I reached the vanity lights. They were starting to light up as I was installing them, then as I finally got it in they didn’t turn on. None of the other lights I installed worked after this either. I heard about the fuse box, I replaced it with the spare ones under the hood but that didn’t work either. Can someone plz help
Yes it is the interior fuse box that blew. Memory fuse IIRC, top right. Don't change it before installing the new bulbs. The bulb holder design is not very good as the two metal bars are close enough together the end of the festoon bulb will short them out.
Got it, and the only memory fuses I know of are 10 and 7.5 (which are the ones I tried replacing), are you talking about the black diode fuse that’s all the way at the top right?
