1 - 11 of 11 Posts
Ipod - Loading Ipod message interupts playback
I searched for a while for ipod problem threads but this one never seems to be the issue...so...
i use the Hyundai cable with my nano 5g and leave it in the center console. Use to leave it connected and it worked flawless for a couple months..UNTIL..i started getting this message
Loading Ipod
folder menu
on my display.
It will come on during the song and stop it for a couple seconds for the message, then go away...but now its coming on every 30 or 40 seconds or so.
Anyone getting this issue and fixed it since?
Discussion Starter #2
Loading Ipod
folder menu
on my display.
bump...changed the message i was receiving (got it wrong)...maybe someone has this problem now..
Could potentially be an Ipod issue. I would take the Ipod, connect it to a computer, and do a complete restore of the software. Then copy your music back on to it. There could be a corrupt system file on the Ipod. If that doesn't work, maybe check the cable or if a friend of yours has an Ipod, try that out in the car.
If replacing the cable and ipod, and restoring your ipod don't work, then maybe take it to the dealer, not sure at this point.
Sorry for interupt ,is is possible for all make of ipod or iphone ,what are the main brands can connect with the gps navigation ?Thanks for your time .
Well it has to actually be an Apple Ipod to connect to the system using the cable provided by the dealer.
Otherwise pretty much every Ipod and Iphone should work with it, although the newest ones may not charge while plugged into the Ipod cable.
It should charge no matter what. The issues with ipods not charging was when the switch from firewire to usb happened
No it was not. Apple slightly modified their cables to transfer more power to newer devices. I know this because when the Iphone 3GS first came out, a lot of cables/devices would not charge it, hence why I had to buy a new Ihome as well as my 09 Sonata wouldn't charge it either.
They may have finally made everything compatible, but a couple years ago newer devices wouldn't charge on older cables, they would transfer data though.
I have the issue with my Blue tooth and my phone list.. Everytime I start the car it has to update the list. Is there [possibly a way to turn off the warnings for both ?
no it was the change from FireWire to USB. The voltage USB puts out has never changed its a standard. 5volt 500milliamp. It was just forced that new devices had to use USB. If u look in apples support I'm sure u can find it. Thanks :)
N
I get the "loading ipod folder menu" message sometimes when I switch through songs continously and too fast. Its seems to only happen every so often so it may be related to a particular corrupt song as mentioned above. It hasn't happened enough for me to really do anything about it. For now, I just switch to AM/FM and then back to the AUX and all is good.
Cece's Daddy
Warranty. That should fix it.
1 - 11 of 11 Posts
