It is plenty safe... you just might leak some boost every now and then. Make sure you ahve a boost only signal going to the CBV to try it's best to hold it shut. So won't break anything, you just might not get optimal performance. I ran like this for a few weeks prior to gettting my turbo. No need to waste you money on a BOP that you will use for a week or so.
I drew this for seomthing else but use #2
red is boost only, blue is boost/vacuum, green is boost/vacuum, but solenoid controlled. That red line comming off of the turbo is actually comming off of the compressor housing.
ignore the other pics.
