1 - 17 of 17 Posts
Since my car is over 50k miles, I decided to purchase and add fuel system cleaner into my gas tank. I read online that fuel system is good to use for cars with high mileage. However I am hesitant to use because exotic cars like porsche and lambo warns you not to add anything unless you are a car mechanic and has deep knowledge since you could clog(?) the engine. Now GC is not exotic but it is to me :) and I want to take a good care of it.
This is the picture of the fuel system cleaner I'm about to add, what do you guys think?
If this is good to use, will 1 bottle suffice? It says it will be good upto 21 gallons which is more than a full tank in GC
GCMafia
It's a waste, as the above poster said. Get gas from chevron on your next fill up.
It's a waste of money but won't hurt the car.
I wouldn't call it a waste.
Polyether amine (PEA) is the main ingredient in fuel system cleaners, it has the best cleaning properties of any other additive. Different products have different amounts of PEA (And some do not use it, since PEA has been declared non-hazardous, it has disappeared from MSDS, making it near impossible to determine if the fuel cleaner has it and to what concentration).
Redline SI-1 had the highest when it was still on MSDS, 50% concentration of PEA. Gumout Regane came in a close second at 40%.
Just because you fill up at a pump that claims it has detergents in it, doesn't mean it has a specific dosage. Much like ceramic brake pads, which are only required to have 1% ceramic compound to market them as 'ceramic', same goes with these pumps selling fuel with "invigorate" or whatever stupid name they have.
Not a waste of money, Hyundai recommends Chevron Techron, they even relabel it and sell it as their own.
Page 1 of 2
Technical Service
Bulletin
Subject
Group
Number
Date
Model
CIRCULATE TO:
GENERAL MANAGER
[X]
SERVICE MANAGER
[X]
SERVICE ADVISOR
[X]
WARRANTY MGR
SALES MANAGER
[X]
PARTS MANAGER
[X]
TECHNICIAN
FUEL SYSTEM
10-FL-014
NOVEMBER, 2010
ALL MODELS
HYUNDAI FUEL SYSTEM CLEANER PLUS
RECOMMENDATION AND FUEL
QUALITY INFORMATION
DESCRIPTION:
Hyundai Fuel System Clean
er Plus (P/N 00232-19047) is
now the ap
proved and
recommended service product for complete fuel
system cleaning duri
ng routine service
and preventative maintenance.
NOTE:
• A 20 ounce bo
ttle treats up to 20 gallons of
gasoline.
• For use in all gasolin
e engines (MPI or GDI
systems).
• Can be used as often as
3,000 miles or at every
oil change.
• Cleans fuel injector
s, intake valves, and
combustion chambers.
• Protects fuel level s
ending units against damage
from sulfur content in fuel.
• Cleans and protects cr
itical fuel system
components from corrosion.
• Does not harm the em
ission system or leave
behind combustion chamber deposits.
Regular use of Hyundai Fuel
System Cleaner Plus with
TECHRON
Technology can
help address engine
carbon deposit related conditi
ons. By removing these
deposits, an engine may ex
perience restored engine
performance and ef
ficiency, smoother
running idle, and
cleaner tailpipe emissions.
GenSport KY
I like sea foam. I called the comp.and they said its turbo safe in the oil also.
Take 'em Fei!
Seafoam is good but clogs the injectors. I know from first hand experience in my gen coupe lol. Had to pull the injectors and have them professionally serviced at 100k miles.
1stgengen
A lot of the carbon buildup in this engine occurs right before the injectors, above them in the runner. Not to say running some injector cleaner wont help, but your better off taking apart your intake, throttle body, and manifold every so often and giving it a good scrub clean. That will go further than a bottle of fuel treatment.
3.5L TT but wrong body
Using it once in a blue moon won't really do anything. It's meant to be used frequently as a maintenance thing... If you already have clogged injectors, which 90% of the people on this forums don't have enough miles for, running a bottle or two won't do anything appreciable. You have to run it regularly to keep deposits from building up.
GCMafia
Lol every time I use it I get a CEL saying a run rich and gas mileage actually gets worst so I don't use it anymore
Take 'em Fei!
Page 1 of 2
Technical Service
Bulletin
Subject
Group
Number
Date
Model
CIRCULATE TO:
GENERAL MANAGER
[X]
SERVICE MANAGER
[X]
SERVICE ADVISOR
[X]
WARRANTY MGR
SALES MANAGER
[X]
PARTS MANAGER
[X]
TECHNICIAN
FUEL SYSTEM
10-FL-014
NOVEMBER, 2010
ALL MODELS
QUALITY INFORMATION
DESCRIPTION:
now the ap
proved and
ng routine service
NOTE:
• A 20 ounce bo
gasoline.
systems).
oil change.
itical fuel system
TECHRON
Technology can
help address engine
performance and ef
ficiency, smoother
running idle, and
Yep, I use this too once right before every oil change and it helped with my injectors. When I pulled them at 100k for their service interval at a local shop that can inspect and clean them, all but one were rated at very good flow and the one that wasn't was still rated good so taking that for what its worth.
I used seafoam in all of my cars and never had an issue with it clogging the injectors.
+1 to Seafoam.
Every 10,000 miles a bottle goes in the tank.
I use lacquer thinner. 50/50 toluene and xylene. Never put it in my Coupe yet but did just add a gallon to a 12 gallon tank on my Accent.
1 - 17 of 17 Posts
