"""Most every other car - lowering the car will give it a harsher ride (less travel and progressively stiffer springs) so you will feel more bumps. if you commute, NOT a good idea unless you dont care about ride quality (i do)
secondly, anytime you adjust anything with the suspension, you should get the alignment at least checked (alot of tire places will CHECK for free, and charge to adjust) this way, you will know if the extra $80 or whatever is worth it
lowering a car will most likely wear your shocks faster than stock height - however up to a 2" drop we'll say the difference should be negligible. anything over a 2" drop and you should most likely look into coilovers
along with that last point, expect some issues if any warranty issues pop up - that will not be covered by the factory warranty (parts & labor can get expensive) so again.. is your car being lowered really worth it?
If my lancer was my only car.. then yes id most likely lower it so i can enjoy a nice looking car with slightly better handling. since its not.. i will prolly wait till the warranty is all but shot to change anything on it (besides lights and other easily swapped out parts)
just writing this for the n00bs out there who just want a good looking lowered car, but dont want a chewed up front end, voided warranty, extra rattles in the car from added vibration, and a harsher ride while driving all over creation.
also... DO NOT just cut coils in your springs... spend the $300 or whatever and get some nice progressive springs (start soft to help with ride quality and progressively get stiffer so when you do nail a nice bump, you at least absorb some of the hit before your travel is maxxed and the frame takes it.
if you want a faster car in the corners... lowering springs are not the best way to go. coilovers all the way. if you are on a budget, fine, but also look for stiffer sway bars to help
as far as fenders... wider tires with a nice offest will look great, but most likely need the inner lip of the fender to be bent up and out of the way - or "rolled". flaring fenders is a bit dramatic for these cars... not a muscle car or hot rod.. just roll them and call it a day. stock car as it sits, my guess is that one can probably drop the car 2.5" all the way around and not have any issues, except maybe some minor rubbing on full lock of the front wheels which is negligable.
those rrm springs someone posted earlier seem good to me, but i would prefer a bit more of a drop - maybe 2" all around."""""
IS THIS TRUE? I FOUND THIS THREAD SOMEWHERE ONLINE...
Im planning to get a pro kit, no too low . but decent low, with performance and the look.
help me out here, thanks guys..
