1 - 8 of 8 Posts
So I recently got a CEL for p2187. Too lean at idle. Someone told me my O2 sensor is hooked up incorrectly(bought the car earlier this month). Here’s a pic. Is this wrong?? Should I switch just the two plugged into the downpipe, or do I also swap the plugged-in part at the top of the picture?
only thing is, I’m turbo back.. straight pipe no cats. So could a incorrect O2 sensor even be the reason for this code?
Motor vehicle Automotive battery Automotive design Automotive tire Automotive exterior
It should be black to black and grey to grey.
Sent from my LG-TP450 using Tapatalk
Ok so the top portion is plugged in correctly, but is the two sensors going into the downpipe correct? Someone very credible told me they are swapped.
Member
They look reversed.
The one that's clipped into the bracket, I have that one going to the first sensor on the O2 housing.
1 - 8 of 8 Posts
