1 - 3 of 3 Posts
Wondering how to get more power to my 2010 3.8, done with the outside time to do engine stuff. Was thinking about a performance camshaft or a ECUs time and chip.
Welcome. An engine makes power by utilizing air, spark, and fuel. You generally don't have to increase spark or fuel unless your capacity for power is greater than the ECU can adjust for. That leaves air, concentrate on moving as much air through the engine as you can (safely). Start from the ends and work your way towards the engine. My recommendations in order (1) Cat-back exhaust, 2.5 inch diameter is plenty., (2) CAI, avoid SRIs that tend to heat soak, (3) Mid-pipe exhaust, 2.5 inch diameter, (4) test pipes, 2.5 inch, (5) canned or custom tune, (6) TB and intake porting. Good luck
Lol, I bought mine I was all like, I'm not doing a thing to this car.
I had a Camaro that was supercharged, as well of just about everything else done.
SRT-4 with stage 2 turbo kit upgrade, stage 3 springs.
But....after about 9 months I just had to start adding things to my Coupe...seems a lot of us start off saying no, but end up saying yes.
1 - 3 of 3 Posts
