1 - 3 of 3 Posts
Is an Authorized Retailer for
BK1 VIS Racing Genesis Coupe AMS Carbon Fiber Hood | Karbon Koncepts
Description:
2010-2012 Hyundai Genesis Ams Carbon V Fiber Hood. 2010-2012 Hyundai Genesis Ams Carbon V Fiber Hood. All Carbon
V products line are produced by using vacuum infusion process. As a result, parts are lighter, increase strength and
durability. VIS Carbon Fiber Hoods and Trunks are made from the finest carbon fiber material available. All VIS Carbon
Fiber Hoods and Trunks are manufactured using a two-part construction design. The top layer utilizes a 100% ISO
certified, Grade A carbon fiber material. The carbon fiber material is bonded to the hood using a high grade epoxy resin ,
and then finished with an ultra-clear (Poly Shield), UV-protective polyurethane coating to ensure a high gloss finish.
Marrying aesthetics and functions, we pioneered the use of one-piece, smooth underside shell which complements the
fine finish on top, and at the same time strengthens the product’s structural integrity. The edges of each hood or trunk
are meticulously smoothed by hands to insure high-quality finish all around. The result is a carbon product that is
unparalleled and excels above all else in quality, durability, and aesthetics. All VIS Carbon Fiber Hoods and Trunks come
with a VIS badge of authenticity. Please be sure to look for the badge when purchasing. Due to the unknown nature of
the intended uses of these products, hood pins are required. These products are intended for off-road use only, unless
your local and state laws state otherwise.
All Carbon V products line are produced by using vacuum infusion process. As a result, parts are lighter, increase
strength and durability.
Vehicle Applications:
2010 - 2012 Genesis Coupe (All Models)
1 - 3 of 3 Posts
