1 - 13 of 13 Posts
Is an Authorized Retailer of
Genesis Coupe Stoptech Stainless Steel Brake Lines | Karbon Koncepts
FREE SHIPPING WITHIN THE 48
Receive 10% off your purchase of 4 Rotors, Pads, and Lines - Click Here*
Description:
Stoptech Stainless Steel Braided Brake Lines provide a quicker, firmer, more consistent pedal response by maintaining
consistent brake pressure. Additionally, stainless steel lines provide precision brake modulation, especially during threshold
braking. The improvement in pedal feel is more dramatic on older vehicles where the factory rubber line may have softened
and swelled due to age.
StopTech brake lines consist of a PTFE (commonly referred to as Teflon) inner line that carries the brake fluid, which is then
covered with a layer of stainless steel woven braid. The PTFE tube is very resistant to expansion under pressure and will not
degrade from exposure to brake fluid.The braided stainless steel provides support for the PTFE and the weave is extremely
durable against incidental impact and abrasion.
Next the stainless braided hose is coated with a clear abrasion resistant PVC cover for maximum protection against chaffing
and strain relief devices reinforce end fittings.A variety of end fittings are available to meet most application needs.
All fittings are engineered for proper fit and durability. All necessary brackets and fasteners are included with each line kit.
This is the same kit we recommend and feature on our "Project Genesis Coupe"
Vehicle Applications:
2010+ Brembo
2010+ Non-Brembo
Brake Fluid - Motul RBF600*
Karbon Koncepts recommends Motul RBF600 It is 100% compatible with your existing brake fluid. While we recommend changing
all the fluid in your lines, it is not always necessary. 1 bottle (500ml) is enough for installing new lines alone and adding fluid.
We recommend 3 bottles (1.5L) for a complete flush
Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen,
increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F (312C)
helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C).
*If purchasing Brake Fluid, your order can ONLY ship via Ground Shipping
Discussion Starter #2
If you EVER have brake line installation or bleeding questions, please let give us a call. With personal hands on experience, we can answer the tough questions that no one else can from YOUR point of view.
Give us a call today!
Discussion Starter #10
Karbon Koncepts is your number one source for braking upgrades. Have questions? We've done it all ourselves!!! Don't ever be afraid to reach out and ask us how, when, or why!!!
1 - 13 of 13 Posts
