1 - 5 of 5 Posts
Hi everyone, I started my car today and noticed that whenever I turn my left turn signal on, the "reverse beep" (manual, 2.0t) sounds off with the blinker. Would this be a short in the wiring somewhere? All of the lights still work correctly so im not sure where this issue would be. I couldnt find any other posts with this issue, any help would be greatly appreciated!
I posted a video to instagram if hearing / seeing it helps: http://instagr.am/p/B6v4Yp3n3Lw/
Discussion Starter #2
Its a 2010 GT (canada, I think its the track model in the states?) Should have specified above
Problem solved: for anyone else with spec-d tail lights, be sure to seal up the wiring connections good. Mine were soaking wet from the melting snow here in Canada, dried them out and plugged them back in and no more beeping. Will be wrapping them up tight after this.
1 - 5 of 5 Posts
