Looking for a tuner
1019 Views 8 Replies 6 Participants Last post by  Fixer
I'm located in Gulfport, MS. I'm looking for a tuner that's experienced with the GC and the CMD. I'm guessing I'm in for at least an 8-9 hr drive each way east or west for a reliable tuner.
If you know of one, post up or PM me.
Thanks
1 - 9 of 9 Posts
Not a one... Wow, this is a little depressing.
Do you have a wideband 02 or just the CMD?
Right now, I just have the CMD. I'll be ordering the WB2 next week. How does tuning the CMD compare to say a mafterburner or FIC?
Gonna say, you either have to go to the northeast or out to Las Vegas/South Cali to find a tuner. That is unless you want to ship it and can tune it. Just not a big enough market yet.
If you have the wideband as well there's no need to go to a tuner. You can use autotune instead. If you want to do it the safest way, load the 20psi map, add 10% fuel to the whole fuel map, and use autotune to lean the mix out.
Otherwise you can load up the 20psi map, set your lamda values to .78 in the autotune map, and go for a drive. Just be sure to monitor A/F when you go WOT. If it hits .81 (~12:1) or higher (leaner) back off the gas pedal, stop the car, add a little fuel in (manually or using autotune) and go for another run.
This is all after you've taken logs to get your clamp values and done the throttle calibration.
Hey I have a white Gen I stay in Pass Christian, yeah my front bumper is fcuked up but soon to be fixed, but about tuning I email a highly recommended turner from baton rouge called corr performance and he said he is looking for ways to tune our cars, but there is a Gen turn somewhere south fl I think, maybe u see me cruising around sometime, at night tho,
Kenny Tran! Jotech motorsports in Garland Tx. i have a CMD on my car and he's done 2 others as well.
+1 for jotech.
1 - 9 of 9 Posts
