In Charge of Snacks
Milwaukee Sawzall? Should be pretty cheap to take your car to any welder/fab shop/muffler joint and have them weld in a simple mild steel pipe after whacking the giant rear muffler off. Other than that, any of the pre-made exhaust pieces(headers, downpipes, cat-backs) are going to be expensive. If you want to get a "better" sound I can personally recommend the resonated test pipes. And they bolt right in. Pretty affordable on Ebay...
2x 1/2 washers
unbolt muffer, remove gasket, put washers on studs, reassemble without gasket
Yoda
Clip some playing cards onto you wheels ;)
Reactions: br2
