1 - 3 of 3 Posts
I own a 2013 2.0t with 96k miles bought it for $3200 due to a blown turbo. I had the turbo replaced, but it is only running about 3-5 pounds of boost. I replaced the BOV thinking that could be the cause of it but it is still only running 5PSI at most. I did have a code for a P0035 fault but it went away after disconnecting the battery hasn't came back since. Any help would be great!
possible the solenoid for the bov, the ewga is back....
BUT it could be they you just have a boost leak.
Plenty of youtube vid on how to test for boost leaks.
ECU in limp mode maybe ? When I replaced my turbo I wasn’t boosting pass 5psi. Figured out it was in limp mode. Bought an unlock from hptuners and haven’t had a problem since
1 - 3 of 3 Posts
