Hey guys.. I’m sure I’m going to get roasted on this but don’t blame you if you do. So I bought some wheels. I got an incredible deal and didn’t ask much questions when buying them. The seller after the fact didn’t know much about the wheel specs because he bought the car they came off of to part out. With that being said I know little about the specs but know they’re ds07’s, the diameter of both the fronts and rears are 18 inches and that the width of the fronts are 9.5 inches. I’m running 245/45r18 in the front and 255/45r18 in the rear. I don’t know the width of the rear wheels or offset of either. Looking up the size these wheels are available in I would guess that the rears are 10.5 inches in width. They have a very aggressive poke to them all the way around. What I’m curious of is what y’all think I should I could do to lower the car a bit. I was seemingly only able to fit 2 fingers between the fenders and tires all the way around. If I had to guess I’d probably only be able to lower it 1-2 inches all the way around, but I’d like to hear what you guys think. This is my daily and the majority of my driving is back and forth to work (highway driving) so the roads can be a bit bumpy at times. I’d like to retain ride quality as much as possible and the struts/shocks have not been replaced so new suspension will most likely be needed regardless of lowering the car slightly or not at all. Thanks in advance
