1 - 13 of 13 Posts
I drive a V6
the manual has a high failure rate in Canada/USA...mine recently let go as well (only 17 000 kms).
There is obviously a flaw in the design.
Are korean owners having similar failure rates?
I refuse to have my transmission changed until Hyundai admits and rectifies the problem with the design.
When I changed my fluid at ~6K kms, it looked like gold paint...I was concerned but dealer said it was fine. 11K kms later and the transmission lets go.
Transmission in these cars = junk.
I drive a V6
looseness when engaging R, 1, 2, 3, 4 (5 and 6 are fine)
Once the transmission heats up, it makes a rattle sound in neutral and even if clutch is fully depressed, while stationary, running the shifter through the gates makes a loud "thump" and can be felt throughout the car and through the shifter. There isnt any grinding, just an overly notchy engagement.
I have to admit, I was sure all these tranny problems were due to driver error...I was wrong.
Car still drives but its just a matter of time.
Out Pissing Off cops!
:squint::ugh::(:wtc:
Really not lucky with your GCs...
/Fingers crossed
As the days go on..
i think mines starting to do the same thing not even 2k miles on it yet
거침없는 크럿&
i know the rattle sound you're talkin about. the Korean gc's have that too. i thought at first it was a rod knock. haven't heard the thump.
but even with that noise, the transmissions are bulletproof. we drift our cars competitively on the track and daily drive/mountain drift, which is very harsh on the driveline, and haven't had a transmission break yet.
hyundai finally replaced my transmisison 2 days ago .. my car is going fine now but i will try to put as much mileage as i can before storing the car for the winter ..
I drive a V6
Discussion Starter #9
They agreed to replace mine too but I am going to wait until spring. I am parking the car for the winter soon, hopefully by spring they will have made a revision to the design.
SUN★WORKS
I had a rattle noise too, even with the clutch depressed. Ending up being the DMF. Mine had excessive play in it. I switch to a competition clutch and flywheel. My rattle has gone away and the trans feels great!
Chuck Norris piss extract
/ THREAD
1 - 13 of 13 Posts
