1 - 20 of 33 Posts
Gooood! GOOOOOD!
**All slots are full, but you can still get in on our regular pricing!** Pm us for details!
MSRP: $999 (YOU WILL NOT PAY THIS :bowdown:)
OUR PRICE: PM US for a steal! :D
**NOTE: These are due to come in next month. Only 5 customers may enjoy our special pricing.**
1. CrookedH
2. Davidld
3. Genjuice
4. MtBonia
5. 3hhh
Model Number : MR-CDK-HG09
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong
warranty.
SPECIFICATIONS & FEATURES:
Application:
Hyundai Genesis; 2010
Spring Rates:
F: 62mm ID; 170mm length; 7 kg/mm
R: 62mm ID; 185mm length; 8 kg/mm
Damper Specs:
F:
120mm stroke; 260mm length; M2 valving code
R: 137mm stroke; 44-210mm length; 44R01 valving code
  • 32 Levels of Damper Force Adjustment
  • Front Upper Camber Plates
  • Pillow-Ball Upper Mounts
  • Rubber Dust Boots
  • Adjustable Ride Height
  • Aggressive Spring Rates
  • Single-Cylinder Design
  • Aluminum Brackets
Damper Setting Info:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
All coil-over damper kits come with 1 year manufacturer-defect warranty.
**All Hardware is Included**
3.5L TT but wrong body
Price to 78660?
Gooood! GOOOOOD!
Pms sent! :D
Gooood! GOOOOOD!
1 spot is pending! 4 remain. :D
newbie
sent you a pm
If the other megan coil GB was a "crazy good deal" as I thought, this one is insane.
Payment sent.
Gooood! GOOOOOD!
Discussion Starter · #8 ·
Thanks guys! Pm sent! Crooked, you will be added to the list! :D
Gooood! GOOOOOD!
3 spots remain!
Gooood! GOOOOOD!
2 spots remain!
Gooood! GOOOOOD!
Discussion Starter · #11 ·
Bump for a good deal! :)
Gooood! GOOOOOD!
Discussion Starter · #12 ·
1 kit remaining!
Gooood! GOOOOOD!
Discussion Starter · #15 ·
Pm's replied! :) Thanks!
Gooood! GOOOOOD!
Discussion Starter · #17 ·
Pm sent! :D
Gooood! GOOOOOD!
Discussion Starter · #19 ·
Pm sent!
Gooood! GOOOOOD!
Discussion Starter · #20 ·
All pms sent!
1 - 20 of 33 Posts
