1 - 12 of 12 Posts
My 2010 Gen Coupe 3.8 Track's fuel gauge has been off for the last few months. I've replaced both senders and the fuel pump, but the fuel gauge will show half full when it's full. I suspected the passenger side sender being stuck as the fuel level would rise or fall depending whether the passenger side was elevated when the car was parked.
After checking and rechecking everything, including both senders, I noticed a piece of metal moving freely in the passenger side of the tank (see photos). Depending on whether it blocks the float when it's up or down, my car will show half full when full, or half full when close to empty. It shifts and not reliable so I have to watch my trip odometer to make sure I don't run out of gas.
What's this bracket? Can it be replaced where it belongs? It's too large to remove via the opening for the sender, but I can bring it up to the hole with a magnet. Would cutting it with handheld cutters, nothing which sparks, and removing it piecemeal make things any worse than they currently are? Is there some way to reattach this bracket to the fuel tank safely so it stays out of the way?
Tire Wheel Automotive tire Hood Automotive lighting
Automotive tire Automotive design Automotive lighting Water Automotive wheel system
If it is/was a baffle it should be attached to the inside of the tank. Lots of tanks have them to help keep fuel from sloshing around to quickly during "high performance" driving. Don't know if there's anyway to get that out of there or not but it could be causing your problems if it's binding up the float/arm in the tank.
I'd try to bend/fold it with pliers so it can be removed through the sending unit hole.
I'm leaning towards pulling it out if it can't be reattached. I'm definitely not up for replacing the tank as long is the absence of the baffle on the passenger side won't cause too much trouble. I'm guessing not as it's not been a problem with it just freely moving around thus far.
When the free floating baffle jams the fuel sender arm on the passenger side, the car resets it's overall fuel economy whenever I park the car. When the car is parked, fuel shifts from driver to passenger side, and with the passenger side arm stuck, it sees it as fuel depleting. Then when it shifts back while driving, the trip computer assumes a fuel fill up and resets the average gas mileage, which eventually leads to a check engine light with a cat converter efficiency message. I almost got a new cat converter before I realized I could get it to reset by parking the car flat and refueling often enough that the tank is always full.
My fuel gauge and check engine light have been clear ever since I pushed it away, but I know it's temporary. I need some advice on a more permanent fix while keeping the car safe to drive.
I think the only permanent fix would be to replace the fuel tank.
For my money I'd just remove the piece and see if there's any problem, I'd guess you wouldn't have any but even if you do your no worse off and would just have to replace the tank at that point.
Bump bump… on my girlfriends Genesis the fuel gauge has been reading half a tank for the past 2 weeks Lmaoo I finally opened up the passenger side to find the same baffle loose and interfering with floaty. How did you remove it or cut it?
At least it looks like you can get access to the tank without having to remove the tank.
On my IROC Z28 (1986) you have to jack it up/block it up, then take the shocks loose and lower the rear axle/raise the car more to disconnect the gas lines, vent lines, etc. and then remove the tank to gain access to the lock ring and pull the sending unit/pump out.
Glad you got it figured out/fixed.
It hasn't been pulled out as of yet, but I expect to have it done sometime next week. I'll update this thread once it's done. I don't expect it to be any worse than having that baffle floating around freely in there.
Another friend suggested just slapping a powerful magnet under the seat to hold the baffle in place somewhere out of the way. I'm skeptical as to how well it will hold up to my driving, but it might work at least for the short term.
I’m sure eventually it can cause harm. On mine It looks like it scuffed the little electrical board the floaty has. It took me around 4hrs or cutting it. It’s pretty thin so it can be bent up. And on the other note I would recommend to do it when your tank is almost empty lol don’t be like me
Discussion Starter · #12 ·
I just wanted to update this post with a positive update. The baffle was painstakingly removed over a month with no noticeable negative effects. My gas gauge is working perfectly now and I'm not noticing any handling problems with the car thus far.
The now correct fuel gauge did not help with my check engine light. The shop told me that it was a cat converter efficiency code. I decided to check it myself and found it's a P2096 which only happens after a lot of highway (high speed) driving and goes away after bunch of city driving. It's not related at all and my theory of the car was inferring something by having constant poor gas due to frequent self resets was incorrect.
1 - 12 of 12 Posts
