2013 2.0t premium running btr stage 1 cuatom tune, cold air intake, muffler delete meth injection not tuned for meth! Had BTR tune car 3 years ago everything was good had head gasket go on me replaced over winter with ARP HEADSTUDS befpre doing head gasket was throwing codes random misfires, and running lean, so i replaced plugs and noticed BTR did not go 1 stage colder and left stock plugs in so i replaced with stock plugs then did headgasket, now car is running alot better but it still throws a code now and then misfire cylinder 4 and 3 switched coils around still doing the same! Now my question is should i gap plugs to .025 and check if that helps? Or just get 1 step colder plugs and gap them to .025.. also when i pulled plugs before doing head gasket they were black as the car was obviously running rich and advice on which way i should go? Is appreciated
From what i read colder plugs benefit from advanced timing. Since your at stage 1 this could go either way really, but i would vote no since you had stock plugs in all this time. So i cannot comment on if you need colder or not. Since you just swapped plugs and the issue started im not sure if i would think the coils are the issue. I would make sure your new plugs are all gaped to the same specification because if not that could cause the misfires. If they are all reading good i would look into coils or goto the shop that did your custom tune. If you had stock plugs in prior and all worked well, i dont see why that cant be accomplished again. Although the gap is important and from what i can also see most plugs can have a bit of variance, especially if you went with stock ones again.
Take the plug out and look at the color on the ground strap; if the temp is right the color changes at the bend on the strap. Dark towards the plug and lighter at the tip.
Related Threads
Hyundai Genesis Forum
2M posts
60.2K members
Since 2008
