1 - 1 of 1 Posts
So a few weeks ago something in my HID wiring harness fried, probably a relay, and I finally am fed up with my set-up. So I decided it was time to go big and throw in a set of the Morimoto M-LED projectors.
First off the retrofit brackets are designed for a D2S projector not the M-LED. So be prepared to do a little trimming (it's actually a lot).
Here are pics of the whole process.
[/url]IMG_20190518_143240 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
Here are all the parts one would need if you want to do this.
Morimoto M-LED Projectors
Genesis Coupe D2S 4.0 Retrofit Brackets
M4 x25mm screws - 8x
aluminum spacers 1/4" - 8x
M4 Lock washers - 4x
M4 Hex Nuts - 4x
various bit of wiring and some 9006 connectors
[/url]IMG_20190518_143349 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
So here is a look at the opening for the projectors you will need to cut.
[/url]IMG_20190518_181359 (1) by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
As you can see the M-LED housings are quite large and hit the existing bracketry in the headlights
MVIMG_20190518_145827 by CHRISTOPHER HOLDSWORTH, on Flickr
Be Prepared to cut a lot out
IMG_20190518_181343 by CHRISTOPHER HOLDSWORTH, on Flickr
Mounting the drivers on the bottom side of the headlight housing
[/url]IMG_20190518_185851 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
Use JB Weld to hold a nut in place
IMG_20190518_184039 by CHRISTOPHER HOLDSWORTH, on Flickr
[/url]IMG_20190518_184043 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
Now on to wiring it. Take the time to do it right, use quality connectors and make sure you properly solder everything
[/url]IMG_20190518_192313 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
Be sure and test everything as you go!
[/url]IMG_20190518_225841 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
[/url]IMG_20190518_225828 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
Also since the paint was starting to peel and fade I decided to freshen up the headlights while I had them open
[/url]IMG_20190518_234157 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
All in all everything turned out pretty well
[/url]IMG_20190519_015317 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
[/url]IMG_20190519_015305 by CHRISTOPHER HOLDSWORTH, on Flickr[/IMG]
1 - 1 of 1 Posts
