1 - 20 of 159 Posts
MR TURBO 2 U
Originally Posted by Tweak
Nope, because boosting a 6 nets more power and torque without straining the block as much
pa...how can this be true? eg: to make 500 hp you need lets say 500psi pushing on the piston in the cylinder this does not change between fi & na in the said engine so to make 500hp it takes same amount of air and fuel to create the same cylinder preasures does it not?
. Hence displacement being a factor in the overall end game.
pa... size does matter!
But I digress...
pa.... digress [daɪˈgrɛs]
vb (intr)
1. to depart from the main subject in speech or writing
2. to wander from one's path or main direction
comon for you is it not?strike that don't want a war!
Someone said "there is no replacement for displacement". Well actually there is.
as much as i would love to agree there is not!!!:wtc:
At 100% efficiency for instance a 2.0 boosted engine at 14.6 psi (+ atmosphere) is in effect a NA 4.0 engine. Actually larger because a NA 4.0 is not 100% efficient. Therefore, there IS in fact a replacement for displacement, it's called FI.
pa... well both are not 100% efficient hence the 1.75 multiplication rule in most racing classes! but agree with you that its much easier to to achieve in an fi car than an na car!!!
But if they are both boosted to the same extent, well of course the larger displacement engine will make more power.
pa....sorry again it also comes down to engine design! just as in an n/a car the better the engine flows the more power you make!
guy's a few things that need to be realised to create power are:
1, displacement swept or forced
4.0l displacement swept or forced is just that 4.0 where the f/i gets its advantage is mechanical advantage less loss due to smaller lighter parts (this is where the above quote by my fellow esteemed member is wrong!!!)
2, charge temp / oxygen content
the cooler the temp the more oxygen content and the more you can rapidly expand this charge = the more burning efficiency = more power!
3, fuel btu, flash rate& octane
the more btu the more expansion, the quicker the flash rate the less advance require the less mechanical loss, the higher the octane the higher the comp or boost all resulting in = better burning efficiency better power!
hope this clears things up!!!
In Charge of Snacks
Well put, convict!. Perhaps a better version of the old "no replacement for displacement" adage would be something along the lines of "more engine is easier than better engine". As I see it, forced induction should be the norm. Surely the efficiencies derived from FI outweigh the expense and complications involved.
MR TURBO 2 U
lol convict!
how is this so when its easier to get better burning efficiency with a turbo?
the beauty of turbos is the power of a big engine with the fuel efficiency of a small one!
can't be done as efficiently with any other form of f/i! (as yet)
MR TURBO 2 U
lol convict!
So you're saying, hypothetically, that say a turbocharged 5.7 chevy small block will be more efficient than a 400ci stroked chevy small block?
In Charge of Snacks
lol convict!
Well, it's very simple, really. What you're missing is that it's about power per dollar, not efficiency.
From a tuner aspect available inexpensive transplants are usually large displacement. I also note, at least in North America, that a Chevy or Ford V8 block is easier to repair and high performance parts with very little need of modification are both readily available and relatively inexpensive. This is of course compared to the performance equivalent smaller turbo motor build.
From the OEM point of view; Why develop a new turbo performance mill when you can just slap in the biggest torquey motor from your range?
Don't get me wrong, I love efficiency! I love forced induction! I'm just answering the question raised here. Namely; why is more displacement easier than FI at the same power levels.
MR TURBO 2 U
ok, i am saying that if you have 5.7 making 650 hp and a 5.7 turbo making 650 hp the drive ability can be better and same with the economy if set up correctly this applies to a 1.0 or a 17.0 just the same as a 5.7
eg: a 4.0 ford na in the same weight car (1950kg/2300lbs?) does 10l/100klm on 98/or e85 and the turbo carrying extra weight runs in at around 9l/100klm on the same fuel and has much more power on tap!!!
MR TURBO 2 U
Discussion Starter · #8 ·
pa...your a bozo i was shittin you!!! lol! sarcasm!
pa...i can see that and advise its the opposite here!
coz you get more greenie grants form the tax payer!
again me too i was giving you a hard time for calling me a convict! when actually they got here free and my parents had to pay!!! (told them they should have gone to england stole a loaf of bread and got a free ticket!!!)
lol convict!
You use this term better burning efficiency frequently but you use it in the wrong context. Burning efficiency is based off of stoich and lambda,if you want to argue, a NA motor has a better buring efficiency do to its ability to run leaner or closer to stoich then its turbo counter part.
If you used the term fuel efficiency different story,but even then cyclinder deactivation has come along way.
MR TURBO 2 U
gen i believe i use the term correctly and by this i mean burning efficiency / engine efficiency is related to, the more air fuel you completely combust the more energy produced the least emissions and waste you emit!
its obvious if you produce more energy your making more power and if its done through better burning / less waste then your using less fuel to do the same job!
stoich well don't get me started! only a few feel my pain there!
its almost like 1:1 bore / stroke or combustion chamber design or port angle arguments they all have advantages and disadvantages!
I know you're from Australia.. but come on.. learn to convert. You talk about other people not taking time to do things, or doing them half-assed?
(1950kg/2300lbs?)
You're on a US forum. I think that's the #1 reason you piss people off sometimes because you're talking metric but not indicating that you're metric. Also, while Korea speaks metric, the USDM Korean companies don't do things in metric.
I'm Canadian, naturally I'm metric.. but I still convert because I'm on a US site.
and fyi, 1kg=2.204lbs
which means this:
(1950kg/4299lbs)
Burning efficiency is just that ,the higher percentage of complete burn the higher burning efficiency and a turbo cant match the numbers of a NA for burning efficiency.
The reason a turbo motor gets better fuel mileage is because its less efficient not more efficient and what I mean by that is, when on low boost or no boost its taking in less air making it less efficient therefore less fuel needed.
As for your statement 650 hp NA 5.7 liter vs 650 hp turbo 5.7 liter, the turbo being the better choice, I 100% agree, much more civil for the street.
MR TURBO 2 U
which means this:
yes i typo'd i'm sorry for not being perfect i promise ill try harder next time some how i typed 2300 instead of 4300 ooops sorry!
MR TURBO 2 U
Discussion Starter · #14 ·
pa...sorry it can, it does and will always, when done right!
pa...ahh? what? break it down a little here, your talking in tongues!
to get better mileage you must have better efficiency
on low boost you have low demand not low efficiency
having variable load / boost keeps your efficiency up
an engine requiring more compression to achieve better burning will benefit from variable compression/boost
an engine never achieves 100% swept volume unless under boost!
so at .01 psi you have 100% swept volume there abouts!
= better efficiency!!!! does it not?
In Charge of Snacks
IIRC there were some engines with properly tuned open intake runners that could achieve positive pressure in the cylinder without FI. Of course that's talking about maybe 102%-105% of ambient pressure. I heard they were
ridiculous to engineer, too. As for the convict bit; I just like to use it and since there was an Aussie chick at my place for a little bit I was in the mood. Better to be called a convict than a Yank, IMO... No hard feelings.
1. B.S.F.C., its just facts, turbo and supercharged motors use more fuel per HP then a NA motor
2. Swept volume does not change when you boost a motor, the air mass within that volume does, which increases the volumetric efficiency of the motor.
MR TURBO 2 U
Discussion Starter · #17 ·
much rather convict than yank at least we have "conviction" and not puppets with a stick up our bum!
no no offence your all cool!
the right cai gives 100% if you try hard enough!
MR TURBO 2 U
Discussion Starter · #18 ·
pa... yes bsfc is part of it but so is bmep and this is where you need to look!
here take a wiki lesson not 100% correct but correct enough!
Mean effective pressure - Wikipedia, the free encyclopedia
lol, you crack me up.Stop spinning your going to get dizzy.
Answer theses question with a yes or no
1 Increase boost, volumetric efficiency goes up
2 Decrease boost, volumetric efficiency goes down
3 based off of B.S.F.C., forced induction motors use more fuel then a NA motor per HP
4 A NA motor is able to safely run closer to lambda 1 then a turbo motor
5 Thermal efficiency of a turbo motor is lower then a NA motor.
These are straight forward question, no need to spin talk circles just yes or no.
1 - 20 of 159 Posts
