Might help a little with voltage spikes like a cap does but I can't see it solving the issue completely. If you require an x amount of amperage than you need that same amperage from you alternator directly. Everything inbetween just buffers and maintains voltage but doesn't supply current which taxes the alternator even more. Are you using it in your GC right now and what amperage do your amps require?
