1 - 3 of 3 Posts
Hey there i just recently bought a really nice set of 2013 genesis rims i beleive rspec they are hyper sliver 19", for my 2010 genesis coupe premium but i need tires for them, now can i go 235/40/19fronts and 255/40/19rears and fit my genesis coupe no problem , and not sit weird? buying tires in couple hours need help assap!, using my winters that came with the care on my oem 18s please help!!! ill take pics of my car and rims to post here nothing special atm..
OEM are 225/40 & 245/40; step up to 245/35 & 265/35... max that will fit i believe is 255/35 & 275/35
I personally think the car drives better with more sidewall.
My winter wheels are 17s (because back in 2009, no one made studded tires that would fit 18s in the right tire sizes) and the car drives so much better.
I don't get as much of the side to side pull as with the 18s (been stated that the stock caster angle is off, and no really way to fix it, unless you modify the strut tower, or shift the K-member, which will slightly change all the other suspension angles)
It might be lessened with a narrower tire, but I haven't fiddled with it to know for sure.
1 - 3 of 3 Posts
