Im about to buy new rims and the ones i want of course are not the same specs at all that we have stock. I just want to me sure these will fit and i know i will need to get hub spacers since the center bore is different.
Size Width Bolt Pattern Offset Hub Bore
20, 10.5, 5x114.3, 47, 74.1
20, 9 , 5x114.3, 42, 74.1
20, 10, 5x114.3, 22, 74.1
20, 9, 5x114.3, 25, 74.1
20, 10.5, 5x114.3, 20, 74.1
20, 9.5, 5x114.3, 36, 74.1
20, 9 , 5x114.3, 25, 74.1
20, 10, 5x114.3, 45, 60
20, 8.5, 5x114.3, 42, 60
19, 8.5, 5x114.3, 41, 60
19, 9.5, 5x114.3, 41, 60
Ok, those are all the specs they offer for our lug fit. Please no opinions on what anyone thinks of 20's, i am also considering the 19's if there is a large price difference but most likely going with 20 if im spending the money. What i am looking for is the safest way to do this without worrying about any problems . I want as wide as i can go in the rear without causing an issue, and i have wheel spacers on now that i would like to get rid of if any of these specs can provide me with the flush look i have now.(20mm spacers in the rear, 15mm front currently) Any help would be greatly appreciated for i have no idea what im looking at lol.
301 whp
Toss out the ones with the smaller center bore, since those would require machining to fit. Larger bore will require concentric rings for a proper fit. +1 on the offsets of 22 and 25, everything else is too big and would require spacers to look right
