Would love to know the exact work required to fix this issue for good. Thanks and this thread is much appreciated.
Ok, I dug through 9 years of paperwork just for you! 😁
So, first they tried swapping out the pedal assembly because one of the engineers saw some irregular voltage readings from the accelerator pedal sensor. This is what I have in my paperwork for parts there:
CUSTOMER STATES CHECK ENGINE LIGHT CAME ON AGAIN AND CAR WENT INTO
TOTAL
LIMP MODE,
PLEASE CHECK AND ADVISE
CAUSE:
WAR P.A HELP
32701R00 PEDAL ASSY-ACCELERATOR
1071
W
1
32700-2M500 PEDAL ASSY-ACCELERATOR
(N/C)
(N/C)
32701RQ0 DIAGNOSTIC TOOL OPERATION
1071
W
(N/C)
FC:
PART#:
32700-2M500 |
We’ll just say that the issue didn’t go away after replacing that. That was in Dec of 2018 with ~55k miles.
Now the part you’ve been waiting for—the wiring assembly that was replaced:
A CHECK ENGINE LIGHT IS BACK ON WITH SAME CODE PRETAINING TO THROTTLE
BODY CODE, PLEASE GET WITH ROD FROM HMA
TO CHECK AND ADVISE
CAUSE: WAR PER PA DEPT GOODWILL
9140100 CONTROL WIRING ASSY
1071
W
1
91470-2M070 WIRING ASSY-CONTROL
1
35100-3CABO ETC-ACTUATOR
1
35101-3CGAO GASKET-THROTTLE BODY
91401RQ0 DIAGNOSTIC TOOL OPERATION
1071
W
35100R1C BODY ASSY-THROTTLE AND/OR GASKET (LAMBDA)
1071
W
FC:
PART#: 91470-2M070
SCANNED AND PRINTED FREEZE FRAME DATA PER ROD'S REQUEST TO BE
EMAILED TO HIM.
PER FSE ROD'S ADVISEMENT,
REPLACED THROTTLE BODY AND ENGINE CONTROL
WIRING HARNESS. TEST DROVE WITH 3 KEY CYCLES.
OPERATING AS INTENDED |
That was done around April 2019 with ~57k miles and they put on about 180 miles on it doing god knows what haha. I’m guessing to see if any codes came back.
I’ll post pictures of the info too in case the copy paste from camera function on my iPhone screwed something up.
Now I wouldn’t go chasing this right away, because that wiring assembly they replaced was over $1k. Sometimes the throttle bodies can be faulty, but if you find yourself having this problem over and over, this is what they did. And now I see that I’ve only put on 10k miles since then, so we’ll see what happens in the next 5k miles 😅
Good luck!
