Right, so hi, I'm new here - I've lurked around a tad, namely at the Manual Transmission Issues thread, because I've been eyeing a Genesis Coupe for about a year now. I'm finally ready to make a purchase in a couple weeks - which is going to be a dream as my current car has decided to throw all sorts of curveballs at me this winter.
Anyway, I have a few questions I'd like to ask you guys, as I'm trying to decide on a model choice here (Between a 2011 2.0T R-Spec and Premium) - I haven't searched, but I'm more looking for straightforward, yes or no answers as to whether or not the information is available on what I want here. Along with difficulty for a few of them. Ultimately this is going to help me make my choice, and get started in the community here. I'm buying from Northtown Automotive if anybody has experience with them, I'm in the Buffalo, NY area - again, if it helps at all. And with that, here I go, and thanks in advance for anyone kind enough to give me some direction here:
1) I wanted the R-Spec model due to the larger rims/better tires, track suspension, brembo brakes and torsen rear diff. Is there any chance if I get the Premium, that they'll be able to order a standard for me, with the R-Spec features listed? I refuse to drive an automatic.
2) Do we know if purchasing and installing aftermarket HIDs for the projector headlights has a warranty impact? I imagine it shouldn't, but Northtown claims they can't install HIDs on my build.
3) Are fog lights hard to install? It was fairly simple on my '96 Celica, just a matter of a relay and the actual lights, since I was pre-wired for them. Northtown says they're not available.
4) Are the bigger stabilizer bars easy/expensive to get a hold of/swappable at order? The Premium comes with 24mm in front and 19mm in the back, I'd like the 25mm front and 22mm rear bars that come on the R-Spec.
5) Same deal with the suspension, would that be swappable at order from the Premium sport suspension to the R-Spec's track?
6) Along with the tires and rims - can I swap out the 18's for the 19's with the better tires?
7) For those with experience at Northtown - do they use the genuine Hyundai parts for "aftermarket" sunroof work? I.E. the control set and still retain the tilt and slide functionality, or will I get something different?
8) Are the 3.8's heated mirrors with turn signals hard to come by, do they come painted, and are they difficult to wire in?
9) What exactly does the 3.8's electrochromic mirror do? Just auto-dim when headlights hit it?
10) Is the cruise system hard to wire in on the R-Spec? Is there a reason it's deleted off that model only? Northtown says cruise isn't available through Hyundai due to liability issues?
11) Same with push start, it's a feature I'd love to have, but I want the genuine Hyundai parts in there if possible. Northtown says this is a Premium model only deal. Is it easy to do/install?
12) Do we have like a parts catalog available with numbers in it and whatnot, in case I would need to order some of these items from the parts shop?
Things to note:
I know I asked a lot of questions, help with any of the following is so much appreciated, as it'll decide what I end up getting. Honestly, I'm expecting flack for coming in and doing this :x
I refuse to drive an auto, so if we know we can't swap the Premium's drivetrain, R-Spec it is and I'll have to aftermarket out what I can from there.
Aside from that, I know I asked a lot of "dealer related" questions. If they can't be answered, don't sweat it, I meet with my salesman again on Friday. I'm just trying to cover all bases as quickly as possible.
I'll be back tomorrow around 6ish, I have to work from 8-5. EST, of course.
First off a lot of the Information you are looking for is available already answered if you had searched for it, my comments are in Bold.
The things on the R-Spec aren't available as options on the premium.
Can't Imagine installing HID's would impact any part of the warranty except the part covering the Headlight and/or that part of the wiring harness. Also don't get HID's installed by the dealer, in fact I'd not get any custom work done by them at all. Aftermarket HID's are your best best, such as the ones available from Diode Dynamics
Fog-lights aren't too hard to install, look around for the DIY on it. Cheapest place to get them from is importshark.com. Again don't have the dealer do it, they are rather overpriced.
If you get the Premium, best way to upgrade the sway bars would be to go aftermarket, look at importshark.com again for that.
Very easy to swap, best bet there is to look in the Private Classifieds for someone selling these (lot's of people do after they get coil-overs)
Again very easy to swap, best bet there is to look in the Private Classifieds for someone selling these (lot's of people do after they get new wheels)
No comment here
You can buy these aftermarket (not sure where), but I can't comment on ease of install
Edited: Oh, yea what JasonG said is correct (thought you were talking about outside mirrors)
I really don't know if it'd be possible to wire in that. It probably involves changing out the wire harness and BCM to start with at least. It's deleted from the R-spec to save weight and money (says Hyundai). The parts are available I'm sure, but your dealer wouldn't want to be on the hook for something like that. If you want to do stuff like that best bet is using a shop that does custom work.
No this would not be an easy/ cheap thing to do aftermarket. I don't know of anyones who's done this, so I'm not sure it'd be possible (using just OEM parts).
This vendor has a pretty good online Catalog Hyundai Parts 4 Less | Genuine Hyundai Parts, Performance & Accessories
Things to note:
Car newb
Yes. It also gives a greenish tint to the mirror when it dims. It's impossible to flip the mirror up like you would normally, but it's unnecessary since it auto-dims. It works quite well, I might add. Had someone behind me the other night where it looked like he had the sun in each headlight on my side mirrors, but the rear view was no problem.
Discussion Starter #4
Right, so in regards to question number 1, I can't custom order a premium with the R-Spec manual transmission/diff/brakes/etc?
If that's the case, I'll have to go with the R-Spec, because I literally fall asleep driving automatics. Can't be done - for my own safety and everyone else's - and it's not as fun. :)
I know there are aftermarket push start options, but I'm a big OEM nut, I kept everything on my Toyota OEM, fog lights, relays, etc. - only stuff you can't get OEM I'll typically aftermarket. The amount of difference it'll make on the loan really isn't a bother to me, so I'd like to have factory options installed first, before I go screwing around with the rest of the car - it's about to be my first brand new car as it is, so I'm kind of afraid to play with it haha.
I'll have to see about that mirror too, I can't stand being blinded. Especially since the car I'm driving right now is dropped, I've got maybe three inches of clearance and everyone's truck or SUV just blinds the hell out of me.
What exactly are you directing me to? I've been through every word on every page of the Hyundai website regarding the Coupe.
