1 - 3 of 3 Posts
I swapped my turbo which had 80k miles on it for one with ~15k miles on it, both being OEM turbos. I also replaced the manifold and wastegate that came with the newer turbo, but now there's no boost being produced. I checked to make sure everything was connected, but can't figure out what the problem can be. I want to say that the new wastegate is not functioning properly. Anyone have any idea or dealt with the same problem before?
You used swapped with a BK2 turbo right? (only asking because you mention swapping the manifold and in the BK2, the turbo is part of the manifold)
With the electronic wastegate? Did you plug the EWG back in?
Take a picture of the setup for us to look at?
I was able to figure out the problem. I had installed the waste gate arm so it would be stuck open. Thank you though!
1 - 3 of 3 Posts
