1 - 5 of 5 Posts
Have a 2013 Coupe track, that's giving me a hard time...Drove the car home, battery light came on...lost all displays in dash and nav....then car shuts down. Jump the car ran for about 10 min, then it shut down....Replaced the battery, car turn on....ran for about 4 hours then car shut down again. Took it to firestone replace the alternator, they charged the battery, but the car still shuts down. Alternator shows its charging the battery, but still shuts down after about 20 min after the dashboard flickers then goes off....Battery light still shows on the dash.. Check all grounding wires....all look good and tight...150 fuse looks good... all fuses look good
What am i missing? Could it be a another bad alternator? or a bad ECU/ECM?
Any impute will be greatly appreciated
I know you said you checked all the grounds/connections but i would double check them first if you already replaced the battery and alternator.
Discussion Starter #4
Just to let everyone know....it was just the alternator, not enough volts....have it replace.... ALL IS GOOD
1 - 5 of 5 Posts
