1 - 3 of 3 Posts
Hi all,
I have a 2013 3.8 Genesis Coupe with 57K miles on it. Last tuesday I had my oil changed and from then i've had my oil pressure light occasionally flicker once I get to my destination and i'm idle. This does not happen everytime probably 10% of the time, it has happened about 3 times in the ~8 days since i've first noticed it.
Took it to the mechanic and they recommended a new oil pressure switch, got a new one in there and the problem happened a day later.
Any recommendations or anyone else had this problem before?
maybe the place you took it to, to have the oil changed, didn't pre-fill the filter before putting in.
Advenio Pariter
The oil filter will fill-up on the first start. Pre-filling the filter is just a precaution. With the Hyundai filters being vertical this is a no-brainer at least for the home mechanic.
1 - 3 of 3 Posts
