Had very bad rattle due to timing chain stretching had timing chain, tensions and guides all replaced now I can here this rattle could it be oil not being kept up in the top of the engine CVVT cams area?
And if oil is draining down from the top of the engine could it be the oil control valves or should I be looking into something else?
sounds too clear for it to be coming from inside the engine, but could be wrong.
Check to see if the heat shields are bolted down.
