61 - 80 of 107 Posts
Will you be trying a touch up or painting the entire wheel? You'd have to account for paint faiding anyway and a perfect match is going to be near impossible over all, paint the entire wheel and it's problem solved.
im getting a new wheel entirely so i'll probably leave it as-is if it looks close enough. i'll consider new paint if it starts bothering me. =p
...4, 3, 2, 1
Yes
I'm getting some winter tires for CHEAP but there's a catch, they are all 255/40/18 Continental ExtremeContact DWS. I have a set of factory 18's from a 2013 Genesis Coupe and need to know the following:
1) Will they even fit on the rim?
2) My 2010 GC Track is completely stock. Will I run into any clearance issues?
I did a few searches and I didn't see anything similar to what I'm doing.
Figured this was a good place to post this question rather than a new thread...
If I were to switch from my non-track 18s to a set of the track 19s and run the factory 19" tires would my traction control throw a fit? The diameter and circumference would increase by .4% up front, while out back the diameter would remain the same (.1% increase in circumference but same diameter... don't know how that works, but that's what the tire calculator says lol).
Just kinda considering a switch to the factory 19s since I figure a lightly-used set could be had much cheaper than something aftermarket. Plus it opens up the option of Brembos :)
Super Moderator
There would be no difference.
It's the ratio of diameter f>r that matters not the overall diameter.
Wow, a lot of info here! The official fitment thread is more for after market rims and is over 120 pages so it's hard to get info from that thread.
I have a simple question with OEM 18" rims- I'd like to put slightly higher profile tires on the rear with slightly lower profile tires on the front to give the car a little rake, or make it look that way just a subtle little bit. Would that throw off the TC and SC? I'm gong to get Garageline spacers soon to make the rears broader too. I like the classic muscle car look.
Something like F 235-40-18, R 275-50-18 but would the TC/ABS/SC be all screwed up?
I've read about people going up to a 285 for the rears, but I am not sure if they have OEM rims. Lots and lots of info.... too much....
HL 24
I have a 2014 2.0 RSpec and was looking to move from the stock 19" to 20"
I would be moving from 225/40/19 front and 245/40/19 rear
to
225/35 R20 front
245/ 35ZR 20 Rear.
I'm very new to this so I just wanted to get a double check and opinions.
thanks.
Getting some 235/35 and 255/35 for my OEM R spec wheels Monday. Hope they look good. Kinda want to go with 265/35 but a little scared it will rub.
I am running 245 front and 285 rear lowered and no issues not running stock rims
Ok so I'm hoping someone can check my math here. The previous owner of my car, who I refer to as "moron", put a terrible wheel/spacer/tire setup on the car. First problem I'm solving is the spacers which are not hubcentric and cause me a lot of vibration at high speed. The wheels both have a 40mm offset. I want to get my wheels fairly flush and I like the 20/20 spacer setup I've seen on a lot of the cars on here. Since I'm under the impression that the stock wheels are a 35mm offset, and provided the aftermarkets are the same width as stock, would I need a 25/25 spacer setup to achieve the same effect? Thanks for any help.
Edit: Also just realized the wheel center bore is bigger than oem, gotta fix that too *sigh*
I have a question kinda similar to cliffsta. I was wondering if the r spec bk1 wheels would fit a premium bk2 without any issues? I read earlier in the thread that the bk1 wheels and bk2 wheels differ slightly so I thought i'd ask before I bought them.
Thanks
