1 - 20 of 6362 Posts
· Registered
This is where we need to compile all of the information needed to upgrade your car's factory wheels and tires. Pictures of setups with tire size i.e ( 255/40/R18 ) and wheel dimensions i.e. ( 18x9.5 +15 ) etc. This will eliminate the question of "Will These Fit?!" by giving users a way to actually see fitment and therefore to decide what wheel they want to go with. I personally love looking at cars with crazy offset and super flush fitment. Whatever your taste, any contribution will be great.
Modifications for getting a certain offset and width to fit also would be good info. Any problems the installer ran into would be a good heads up too, like wheel rub when turning, etc., etc.
I will get things rolling. This is a good setup that fits flush and retains a functional and aggressive look.
Front 19x8.5 +15 w/ 245/35/19 tires
Rear 19x10 +20 w/ 275/30/19 tires
Other details you may want to know:
Center Bore:
67.1mm
Lug Pattern:
5x114.3
· This is for the A$$ Men..
Just went with:
5Zigen ZR+250 Matte Bronze on Red coupe
Front: 18x8.5 +25 using stock rear tire - 245/45/18
Rear: 18x9.5 +20 265/40/18
Will post pics when I get them on....
· Registered
3500? works aren't even that much unless you are special ordering colors....
I really like the concave RPF1's or some emotion xd9's with a nice lip. Both of those won't cost an arm and a leg and will look awesome.
I'm thinking 17x9 low offset all around. yummmmm
· Registered
Tenzo Wheels
I found these tenzo wheels yesterday. I wish I waited to get my wheels for better fitment. I might upgrade them next year if the wife is willing, haha.
Tenzo Cuzco V1 19X8.5 +20/19X9.5 +20
Tenzo Type M V1 19X8.5 +17/19X10 +22
Tenzo DC5 V1 19X8.5 +20/19X10 +19
Reactions: devinsidhu
· It is not red. Not red..
4x4?
I like it?
· Shut up and take my money
· Banned
that's not bad.. def far from a 4x4 look, I like it. What are the specs on those wheels?
5zigen ZR+520
From GenRaCER
18x7.5 front 18x8.5 back
37offset 32 offset
Supposed to have spacers, but I had a problem with them. I bought these specs so I could just swap my tires back to the OEM's if need and keep the same FLUSH IT look.
I would have gone wider, atleast a little bit, stock tires can still go wider up to I think an inch (8.5 front 9 rear) if I remember right. But you'll probably get to see my car in person rather than just pics like everyone else. lol
spacers are in my living room, springs should be here Thursday
As four your 4x4 look, it looks stock height to me, which is much lower than most production cars. lol
· Registered
Discussion Starter · #19 · (Edited)
5zigen ZR+520
From GenRaCER
37offset 32 offset
If your not willing to buy new tires, dont waste the $ on new rims. The whole point of buying rims is to give the car a more aggressive look and improve performance right? Wider is better, etc. etc....plus, there are way better tires out there than whats on the car stock.
Spacers.....why? You should have gotten a lower offset...no reason to run anything higher anything in the +20 range. Look at the first post, Grimm's car has Front 19x8.5 +15 w/ 245/35/19 tires and Rear 19x10 +20 w/ 275/30/19 tires...and fitment is GREAT....now, your running 18's...so that means you can fit something even more aggressive, and by looking at that pic, his wheels fit flush and aren't crazy....with coilovers slammed with some camber they would clear fine.
You should have gotten these on all 4 corners....
18x9.5 +20.....they have the deepest face in those wheels...DEEP TYPE 3!!!!..mmmm...right now your deep type 1 upfront, type 2 in the rear....so unbalanced looking!
...and WHY did you stagger. There are so many reasons why not to run staggered wheels. 1, you cant rotate, so have fun buying new tires soon. 2, your front will understeer more now than ever, simply because the rear has a wider track and will literally push the car through a corner, and 3, it looks lame.
If you want wheels to fit on your car, make them fit! God made hammers and baseball bats to roll and pull fenders with! :)
And also, i ran spacers for years drifting and on my daily driver....and i noticed something, wheel bearings pooping out on me after like half a year. Wheel spacers put stress on the entire hub assembly and dont allow the wheel to actually be mounted flush to the hub itself. A lot of cheap spacers have uneven surfaces that result in uneven tire wear, noise, and bad bearings. Be careful, and just order wheels that have a nice offset. IF anything, order something you think is a little much, chances are with some camber and the right tire choice, they will more than likely fit perfect.
Just some info from my past experiences.
· Registered
idrum, did you really just ask why someone put a staggered wheel set on his coupe? you do know it comes that way STOCK and to go with unstaggered wheels will kill the way the car handles?
