261 - 280 of 6312 Posts
Grand Master fLush
My last set of 20s they were Vossen 082
20x9 32mm 245/30 (pretty flush not super flush still within inside the fender)
20x10.5 42mm 275/30 (still have 10m between inner fender and top of tire)
Repost from page 5. We didn't put the alignment specs back to stock yet. The rears are at 0 camber
Here are some proper shots of the 5Zigen ZR520s on the BK -
18x8.5" +32 up front
18x9.5" +30 in the rear
(my offset numbers may be wrong because I honestly can't read the stamp inside the rims)
*I had to use 15mm spacers to clear the coilovers up front*
is that a drag radial i see sir ;)
very nice.... with em only on the back i thought they were D.R lol... very nice look though...
For the love of drifting
hi guys! i'm new to this site. i'm about to order a yellow GC entry level only.
i hope you guys can help me. i do not want to go staggered since i will be drifting my GC so i want to rotate the mags to save some money.
i'm thinking of going 18 x 9.5 and 255/40/18 for the tires. what do you think? I'm hoping that at least the front fit's flush. i guess i have no choice but to put spacers for the back. don't know if that's such a good idea though. would appreciate your comments. thanks!
With that size you'll need spacers to fit the fronts on, otherwise they'll bump the coils. You'll mess with the car's handling a bit by going with non-staggered wheels, it was designed to be that way.
Spacers won't be an issue if you use high quality hub-centric rings such as the type Superdrift sell.
Thank you for the advice! I also forgot to mention that the offset will be between +18 to +22 max.
If i do go staggered, would these be flush and won't need spacers?
Front - 18 x 9.5 +20 or +18 (255/40/18)
Back - 18 x 10.5 + 20 or +18 (275/40/18)
F19x9ET-10 R19x10ET-20
^ that looks like my set up...if you dint want to run so much camber...I would recommend going +20 all around. I'm running close to -3 camber up front and close to -4 in the rear. And to answer your question...you'll be running the "hellaflush league". I just hope that you're running on coilovers.
Thank you for the advice sLydFX! I really like your car. I want mine as flush as yours. what coilovers are you using? and how much did it cost you?
And are the tire size i posted the same as yours?
^ pm sent
^ pm sent
Thanks! I've seen this already when i was surfing this site before joining. And let me say, you have one amazing ride! Your car is one of my favorite here. Not overdone, simple and very jap like.
I have a problem though now. The manufacturer who will do special mags for me can't make 10.5 for the rear!!! Darn it! if i stick to 9.5 for all, what should be my offset in the rear? +20 still and spacers?
so sad... :(
거침없는 크럿&
crappy cellphone pic. try to get better ones later today.
Work EWINGS F18x8 +7 R18x9 +7
thinking about gettin something wider with slightly more poke.
You say entry level yellow GC.I think the yellow only comes in the 3.8 track which means it's fully loaded no other way to get it.19"rims etc.
Can someone help me out and point out some differences in ride quality or how the car would handle if I went with either a 19x8.5/19x10.5 or 19x9.5/19x10.5 set up?
