6281 - 6300 of 6305 Posts
That Guy
Finally got everything installed the coilovers still need to drop a bit but she fit almost perfectly with my stock spacers no rubbing at all. Thanks for all the info guys!
F 235/35/19 8.5" wheel +18 offset
R 255/35/19 9.5" Wheel +13 offset
I'm planning out a lot of mods on my car right now, and hoping to get some help. I'm going for power (~600), performance, and looks. I'll be using brembos and most likely air suspension so my setup will need to clear those. I'd also like to get the wheels as close to flush that I can while my car is lowered, I'm willing to get the fenders pulled if needed but would like to avoid if possible. For specs I've seen 18(or 19)x9.5/+22 front, 18 (or 19)x10.5/+22 rear but not sure how those will work for what I'm looking for. I'm all ears on suggestions, thanks
New Wheels & Tires
Want to send a SHOT out to L8Braker .... If it were not for him i would still have stock wheels and still be searching for the right size and offset to get it done .. You are the man and i can't say thank you enough.. The fitment was ABSOLUTELY amazing ... !!!
These are the TSW Rivage:
Front's are 20x8.5 with 265/30/20 +20 offset
Rear's are 20x10 with 295/30/20 +25 offset
APOLOGIES FOR THE **** RESOLUTION... I usually use my DSLR to take pictures of things i care about their quality... But since its down, i had to settle on my cell phone which i do not prefer because .... its a smart phone, **** lens, **** pictures... Anyways here ya go
These are the old oem wheels:
These are the new wheels:
These are the 1st set of fronts that i got that i didn't really like, 255 on the 8.5 inch wheel, as you can see there is a SLIGHT stretch on it, enough to bother me to the point of not liking it one bit, so i took them off:
So i went with a 265, MUCH better flush fit, now i like :)
These are the rear's:
I would have bet money you couldn’t pull off the 265s in the front, but you did it! Looks great, congrats!!
yea man that 255 had that slight stretch to it and it was enough to bother me ... Every day i looked at them, i was like.. NO that can't stay like that.. Got to go one step wider so i went with a 265 and it was PERFECT ... I mean FLUSH fit and i was like NOW it looks good ...
Thanks again, without you, id still be looking and researching .... !!!
remake kit
Is their anyone out their with the remake kit on their Gen that can guide me in the right direction of getting my fitment to fit nicely (flush) with the wide fenders? I am currently sitting on BC racing coils and stock wheels. Any help would be greatly appreciated
IG: jasonlikedthis
My buddy has the widebody. His specs are 19x10 -15 and 19x11 -20 and sits pretty flush.
I was looking originally into going 19x11 -20 and 19x12 -30 with 255/35 and 275/35 but I figured I needed spacers for that look. If I can achieve what I want without spacers I think I'd want to. I wonder if he runs spacers on his setup and what tire size. Thanks for the reply!!
Call me nuts, but those tire sizes seem nearly impossible with those widths. My fronts are 245 on an 8.5 width and there is mild stretch, but 255 on an 11??
There are a couple guys I know running 255 on an 11! For sure there are better setups out there that are easier to achieve for this kit, that's what I'm here to try to figure out!
IG: jasonlikedthis
Why would you need spacers when those specs are pretty aggressive? Here's a pic of my buddy when he was running 19x10 -21 and 19x11 -39 with no spacers. Not sure what tire size. He said it was too aggressive for his tastes and ended up buying new wheels with higher offset.
It's possible. I'm running 255/35 on 19x11 currently. Some stretch there but I've seen way worse lol
So I have 19x9.5 30 F 19x10.5 30 R .
Not the most common setup seeing as they were for my 370Z that I totaled . The rear fitment is great with BC Racing coilovers . I get slight running when I hit a big pothole but it’s really rare . Where as the front was the issue where the tire was hitting the coilover . So I have some generic little spacers on it to back it off but it does not fit snug under the front fender so the front is lifted slightly with the coilovers . I am running obnoxious tires on it at 275/35R19 in the front and 285/35R19 in the rear . So I’m currently working with a couple of my buddies to find out where the sweet spot is without needing a spacer . Will keep you guys updated tho. If you want to see pictures of everything they’re on my car Instagram that I don’t really use anymore but a lot of examples of the fitment . Dazed_co
Before anyone gets their panties in a bunch, yes I tried using the search function but it was useless.
Anyone running a square setup with 275/40-18 with 18x9.5" +22 on all 4 corners? If so, any issues? I'll be running this on road courses, not just street.
Stock R-Spec suspension, and camber will be around -1.8 front, -2 rear.
TCS issue?
Hi guys,
Hope anyone can enlighten me. Planning to buy 235/35/19 to replace my front tires and I'm wondering if this would mess up my TCS? I'm running stock rears 245/40/19.
Thanks a lot!
So I've decided that I'm going to buy Forgestar f14's since they're on sale for 200 off. I'm going to get the SDC 19x9.5 and 19x11 and for offset I'm thinking around 8-15ish for front and around 18 for the rear. I"m trying to achieve a flush/tucked look and have as little rubbing as possible. Based off everything I've read on the forum I think 235/35 and 255/35 is the move for tires? I"m currently stock height but I do plan on lowering when the rims come in either with PBM or BC. I prefer PBM but I'm not sure about clearance with the rears. Any help with offset/tires would be greatly appreciated thank you for your help.
IG: jasonlikedthis
Hi guys,
Thanks a lot!
Running 235/35 will be fine. No problems with TCS.
Pretty much the same specs as mine. At stock height the wheels will definitely poke. Lowering it and having about -2 camber will fit and tuck tire easy. You may need to roll your fronts but really depends on how much camber you run. I rubbed on bridge bumps on the interstate so I just went ahead and rolled.
Okay that sounds like the move then. Your car and another coupe I saw on fitment industries is the look I'm going for so hopefully it'll work out. I'll definitely post pics in 2 months or however long it'll take to ship. Thanks again for your input.
hey, im new on the forums and yall have probably talked about this here but, I just bought a white 2011 genesis coupe 3.8 r-spec, and im in the market for new wheels but I don't want to spend more than say 800$. yall got any suggestions for a good 19in or 20in. id prefer these sizes so I can eliminate as much wheel gap as possible without running drag tires lol. i want a meaty setup tho so im thinking 19s. just looking for suggestions on what looks good and whats a good quality wheel, thanks guys
