1 - 20 of 2365 Posts
Take 'em Fei!
Per request, and to help minimize clutter, I have created a new thread for this issue similar to what I did with the Hood Alignment issue. First and foremost, I want to recognize Quartermaster for originally getting the ball rolling with his poll thread which you can read at:
Poll: 5th Gear grind survey for HMA mgmt
Hyundai Motor American Consumer Affairs will now monitor this thread to get an idea of who all is having this problem.
If you are having any type of major grind or issue with your manual transmission, please copy and paste the following:
Username -
Location (i.e. city, state) -
Engine/Trans/Trim -
Mileage -
To what degree is the problem? -
What have you done to try to get it fixed? -
THIS DOES INCLUDE CANADA as I am sure Mrs. Lenderman can relay the information for the community
Mods, if possible please sticky this for the time being to help HMA. Thanks.
Bill
Take 'em Fei!
Discussion Starter #2 (Edited)
I will now qoute/add those that have already posted:
Red Raspberry
Ashkum, Ill
2.0L track with 6 speed manual
<3k miles
5th gear grinds unless slowly shifted
An inconvenience now
Nothing to try and fix, will not take to dealer (Brown and Brown Hyundai, Bourbonnais Ill.) until it is so bad they cannot make excuses.
Username - Badcompany235
Location (i.e. city, state) - Coastal Ga
Engine/Trans/Trim - V6/ M / T
Mileage - ~16 000
To what degree is the problem? - 4th to 5th & 6th to 5th. affects ability to merge on highways and slow down.
What have you done to try to get it fixed? - Dropping the car off at Hilton Head Hyundai on the 26th. Will replicate issue with service manager in car. I have not changed fluid from stock. i do not have my case number but have attached dealer info.
Service dept contact
Phone: 800-457-8313
Fax: 843-208-1244
Email: [email protected]
Quartermaster
Mission Viejo, CA
2.0T / Base / 6spd
8800 miles
- 5th gear heavy grind unless very slowly shifted.
- violent 5th-4th gear downshift engagement (snapping/grinding sensation) unless very slowly shifted.
- Changed fluid to Redline MT90, noticed a vast improvement in shifting feel, ease of movement, and grinding was substantially reduced. Grind is still noticed especially in the downshift to 4th as it's obvious the synchros are taking forever to spin up.
Username - davidp
Location (i.e. city, state) - Quebec, Canada
Engine/Trans/Trim - 2.0T premium 6 speed
Mileage - 4500km
To what degree is the problem? - i'd say that the problem is really annoying .. 5th gear is grinding all the time, second gear is really hard to engage when at slow speeds in city traffic...
What have you done to try to get it fixed? - nothing yet i'll contact the dealer to see what they will do ..
Username - [email protected]
Engine/Trans/Trim - 3.8 Base 6spd
Mileage - 12 500 km
To what degree is the problem? - 5th gear grind, all the TIME! 2nd gear is extremely notchy
What have you done to try to get it fixed? - Nothing?
Username - briansol
Location (i.e. city, state) - Bristol, CT
Engine/Trans/Trim - 2.0t track manual
Mileage - 880 miles
To what degree is the problem? - 2nd 4th, 5th, and sometimes 3rd and 6th grind (or otherwise make a 'clunk' noise when entering the gate). 1st is REAL tough to enter the gate when cold at a dead stop (pretty normal i think though).
What have you done to try to get it fixed? - waiting to see what others are doing. considered a fluid flush. I don't drive the car much, so it's not a huge issue to me at this time.
Token Metro Guy
Username - brandon1987
Location (i.e. city, state) - Calgary, AB, Canada
Engine/Trans/Trim - 3.8/6mt/Canadian Base
Mileage - 7060kms
To what degree is the problem? - 2nd gear is extremely clunky. When it's cold out, 2nd gear will occasionally grind when shifting from 1st, or will block me out until I am doing less than 20km/h when downshifting from 3rd. With the exception of the clunkiness, all of this is only when the transmission is cold.
What have you done to try to get it fixed? - Waiting to see if the problem worsens, am considering changing the transmission fluid to a higher quality.
Torque Junky
Username -Tony20tGEN
Location (i.e. city, state) - Miramar FL
Engine/Trans/Trim - 2.0t 6spd track
Mileage - 1500miles
To what degree is the problem? - If I shift from 4th to 5th quickly before the rpm falls it grinds every time.
What have you done to try to get it fixed? -I wait an extra couple seconds for the rpms to fall before shifting. Getting Rev hang issue fixed by dealer now maybe the rpm falling to rev match quicker will fix this.
Username - Paulicat
Location (i.e. city, state) - Mississauga, Ontario
Engine/Trans/Trim - 2.0GT MT 6spd
Mileage - 11,000 km
To what degree is the problem? - 5th gear has a clunk when shifting into it at 3000rpms or higher (just around highway speed of 100km/h).
What have you done to try to get it fixed? - Will bring to dealers attention on next oil change (within a weeks time).
traction control off =]
Username - cant stop spinnnig
Location (i.e. city, state) - quakertown, PA
Engine/Trans/Trim - 2.0T manual, track edition
Mileage - 4,700
To what degree is the problem? - every time you shift into fifth gear at a fairly high RPM you will hear a grind.
What have you done to try to get it fixed? - Nothing yet, waiting to see what happens...
Username - 2.0t
Location (i.e. city, state) - ottawa canada
Engine/Trans/Trim - 2.0T manual, GT
Mileage - 11000kms
To what degree is the problem? - at low speeds shifts are dificult to put into the appropriate gear. like shifting to first when rolling at under 10kph.
What have you done to try to get it fixed? - apparently changing the tramsmission oil really helps this but when i asked the local dealer they told me if i put anything but the recomender oil that it comes with then i will void my warranty. wich is rediculous if the car runs smoother then how would i be causing damage?...
Carbon-based lifeform
User Name: waz
Engine/Trans/Trim - 3.8/6 speed manual/GT
Mileage - 1300 miles
To what degree is problem? Difficult to shift into 1st gear when engine is cold. Feels "crunchy" and bifurcated. I'm hoping that other problems don't develop later down the road.
Username - genecide
Location (i.e. city, state) - burlington canada
Engine/Trans/Trim - 2.0T manual,premium
Mileage - 3000kms
To what degree is the problem? - shifting into first gear unless the car is totally stopped is impossible. 2nd gear is very notchy when trying to shift at higher rpm from 1st. In the morning until the car warms up trying to shift in the 2nd is like finding your way through a maze .Overall very very notchy!
What have you done to try to get it fixed? - talked to the dealer ,said its new and will get better when i break it in. Will bring it up again @ first oil change.
^not very creative.
Username: Tsukuba Coupe
Location (i.e. city, state): Irvine, CA
Engine/Trans/Trim: 2.0T/Manual/Base
Mileage: 4700 miles
To what degree is the problem?: almost every time I shift into fifth over 3k rpm and downshifting sometimes.
What have you done to try to get it fixed?: I've talked to a tech, but haven't done anything yet.
2010 2.0T Manual base car
Username: brad fischer
Milage: 6000 km
To what degree is the problem?: stiff shifting especially when cold. notchy clunky shifts especially 1 and 2.
What have you done to get it fixed?: Talked to dealer, waiting to see if it gets worse or better when fully broken in. getting rev hang reflash at dealer next week hope this helps with 1-2 upshift. waiting to see if there is a dealer or factory recomended trans gear oil upgrade to Redline or other brand , or a lighter viscosity gear oil, or synthetic oil.
Brad STOCK CAR NO MODS
4th color - 4th wheels
Username - genesilexx
Location (i.e. city, state) - Arlington, Texas
Engine/Trans/Trim - 2.0T/6speed/Premium
Mileage - 8400miles
To what degree is the problem? - Im really afraid when I shift into 5th gear, I do it 10 times slower then when I shift into any other gear. Sometimes it catches on 3rd gear too and grinds a little.
Nothing...yet.
Like the third time I have done this but...
HardMacK
McKinze S.
Surprise, AZ
2.0T Track
5900 miles (now... first noticed 3500miles)
Degree of Problem - Any time shifting to 5th under power (ie Accelerating at any speed) fifth would grind, catch or otherwise not engage
Fix? - Dealer replaced all six syncro's and cones in transmission; Inspected by HMA Engineers. After 1000 or so miles fifth gear is now loose and feels gummy and numb, sometimes will not engage into gear without going back to neutral and reattempting shift. This occurs 6-5 and 4-5 at different speeds and clutch engagement points.
Username - steagle
Location (i.e. city, state) - Los Angeles, CA
Engine/Trans/Trim - 3.8 M/T Base
Mileage - 2600 miles
1) Serious grinding on every upshift into 5th, occasional grind when downshifting. As if the gate is blocking the stick from entering.
2) Get transmission clunks in first through 3rd gear if revs are not perfectly matched.
3) Second gear can be near impossible to downshift into at certain times.
What have you done to try to get it fixed? - Brought it to my dealer's service department, they noticed the 5th gear grind, told me they adjusted something in the transmission and gave the car back but there was no obvious immediate difference and now it's worse than before I took it in. I am scheduling another visit. I do not want to bring it in a 3rd time for trial-and-error troubleshooting so I really hope there is some resolution and plan of action after they look at it again.
Sex Machine
User Name: Spool2Go
Engine/Trans/Trim: 2.0GT 6speed
Mileage - 4800km
To what degree is problem? Difficult to shift into 1st gear when engine is cold. Almost to the point where I have to force it in.
What have you done to try to get it fixed? Nothing, I'm just waiting for a fix on this problem.
Username -jr2.0t
Location (i.e. city, state) - Forth Bragg NC
Engine/Trans/Trim -2.0t/ manual/ track
Mileage -3,700
To what degree is the problem? -1st Transmision at 756 miles made grinding noise in all gears, second transmission has clunk noise when I aply 1st at any stop, like is a lot of play in the internals.
What have you done to try to get it fixed? -1st transmission Myrtle beach dealer replaced it next day with a new one. Second one and Im just waiting to see what is it that Hyundai of america is going to do since is a common problem on the trany.
Very difficult downshifting 2 to 3 and 2 to 1 when the car is cold.
Very difficult starting off in first at times. It seems as if the throtle has a mind of its own.
I have driven standard shifts for over 30 years. This car ihas been the hardest to get used to.
I have done nothing about these problems so far. Waiting to see if there is a Hyundai fix. Otherwise I have chosen to live with the minor annuyance.
Username: F40
Location (i.e. city, state): Acworth, GA
Mileage: 1986 miles
To what degree is the problem?: almost every time I shift into fifth over 3k rpm and downshifting sometimes. Also, 2nd is a pain to put into gear!
What have you done to try to get it fixed?: Dealer hasn't heard of this problem.... Of course
