1 - 8 of 8 Posts
Hello
So i have a small question, the oil feed line started leaking in my 2.0, and as usually I'm already waiting 2 weeks for the dealer to get me an OEM replacement (This is official Hyundai dealership - and i don't think they will get me anything)
So, i took off the damaged feed line, cut it open and as it seems the internal diameters are:
- Steel tube 4.5mm ~5 mm
- Ruber part of the line ~6.2 mm
Now, i CAN order a custom made line to fit, with PTFE core and steel braiding, but they only offer 3.5 mm internal diameter, so it may be a bit more restrictive than stock 5/6mm
Would that be a problem four our turbo?
Anyone runs smaller oil feed lines or is this a no no?
I won’t speak to specifics, but in general, logic suggests that restricting oil flow to a turbo would be a no-no.
If you’re dealer can’t find or get you the correct part, it’s probably time to try another dealer. There are a handful on the internet that will have vastly better knowledge and inventories to get you taken care of.
ATP has a kit with a reducer bushing that screws into the turbo
ATP-OIL-021 -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor
ATP-OIL-035 Oil Feed Line -4 - SS Braid, 18 inches length
On stock we don't have any restrictions correct ?
As i said stock line is 4.5~5 mm internally in the narrowest point, I'm wondering if switching to 3.5 mm would hurt that turbo.
I've been using the ATP oil line for 6 years now. I did change out the banjo bolt to a regular AN type fitting at the oil filter adapter and a little bit longer line. But that kit will work. Just connect the banjo bolt end first.
Discussion Starter #7
Thank you for the info
Well it seem sthe official Hyundai dealership in Poland finally got the part for me (2 weeks time)
So i will install OEM, although as it seems just crimping your won custom PTFE / steel braided line would actually be cheaper and better :)
Any way thanks for the responses
I ended up stripping the hole where the banjo bolt threads at the oil filter adapter as it got removed so many times while I did oil cooler work. But I like it much better as it now has a 90* 4an flare x 1/4" NPTm on there. The 1/4" NPT threads are easy to tap on the aluminum. Just don't tap too deep. Just takes a piece with the another flare for the turbo end reducer fitting. My line is 24" and maybe an inch too long.
Since this pic I have also added a 30" line to remote mount the yellow oil pressure sender as it was having reliability issues and was difficult to get to. Also isolates it from vibration.
1 - 8 of 8 Posts
