The dealer is trying to rip you off. I would start by thoroughly cleaning the engine so that you can see where the leak is really coming from. My first guess would be the valve cover gasket. That is an easy DIY. Since it is dripping down the oil filter housing that pretty much eliminates the turbo as it is in the back of the engine. Could be an oil line too. Again, with a clean engine it should be much easier to pin-point the location.
I had a small leak on my turbo return line. All I did was reseat the spring clip and it never leaked again. The fix could be that simple once properly identified. Degrease the engine and be patient when looking. I am hoping it is something small and easy and NOT a ridiculous $10k!!
