Hello guy’s I have a question for y’all I have a bk1 and I’m looking for some info on doing a drill and tap into the top of the oil filter housing
Great trick and tips there!You don't want to use a tee on a temp sensor as you only get the temp of the tee. I drilled and tapped the metal water manifold for my sensor threads.
You can get an adapter that is 1/8 BSTF x 1/8 NPTF, then use a 1/8NPT extension hose to run it out to where you can get to it. My AM gauge oil pressure sensor is on the end of a 18" hose up by the battery.
