1 - 3 of 3 Posts
On my 2013 Hyundai Genesis coupe 2.0t base, I turn my car on, the car is fine, but when it warms up, the oil pressure light sometimes flickers. My main issue with the oil pressure switch is when I am driving my car the oil pressure sensor light flickers precisely every time I hit a bump. I am thinking it is a wiring issue as I swapped my oil pressure switch sensor for a new one and made sure multiple times that the connector is plugged into it. I am making this post to see if anyone has dealt with this problem before.
2014 Hoondai 🏎️💨 GC 2.0T FBO+SFR
Usually when there is a malfunction like this when going over bumps it's related to wiring issues and can be diagnosed with the wiggle test.
Besides that is there enough oil on the engine? Does the light flicker only when warm temp, not at all when cool even over bumps?
Last time I had a oil light flicker a bearing went out.
1 - 3 of 3 Posts
