1 - 20 of 20 Posts
So the current sandy plate I have is leaking, So im looking for a new one that would hopefully prevent this. Now I have a oil pressure/temp. But later down the line I plan on adding a oil cooler.
I read here on the forum that snoopy had no issues with this plate
Oil Filter Sender Adapter - 20mm 1.5 Thread
Will this work with 2 sensors? Plus the addition of an oil cooler, with a bypass for when the its below freezing? Also if you guys recommend a sandwhich that wont leak that would be great!
which one are you currently running? i ordered the glowshift one in the link u listed, havent had a chance to install it yet though.
I just have a universal one at the moment
I have a Blox one. I though it leaked until I checked out the plugs they used. They were simple allen set screws and not a tapered plug. Switching to the tapered plugs fixed the issue.
Is This the one you used?
Oil Filter Block Adapters
Does it allow for both an oil temp and pressure?
Yes that's what I had. The only problem with these types of adapters is where the oil pressure is taken from and that is before the filter. OEM Hyundai has the pressure sensor after the filter.
Hyundai's oil filter spec is a 20 psi differential before the bypass on the filter opens. So the pressure will read higher than it really is after the filter.
Yah, i noticed my oil pressue is quite high when on the highway +60psi, I guess this would explain why.
The only problem with the Blox, is that it does not say what size of sandwhich plate it is or how many 1/8" NPT ports it has
That's where my oil pressure sender is at now too. I need to move it to a tee with the OEM sender.
I'm not saying the pressure will read 20 lbs higher all the time. It is only when the filter is impeding flow to that point.
Unless you know your oil temp is too high I doubt if you need one. Don't know what the conditions are where you live.
If you drive it hard or track it or live in the desert then you probably need it.
But the Mishi is a good one.
Discussion Starter · #11 ·
I do plan on tracking it this year, I got it in aug last year and didnt have a chance to go last year, but after reading about high temps when tracking i though might as well kill 2 birds with one stone. In summer it is 34-40c. Im also hoping that this sandwhich plate wont leak
Discussion Starter · #12 · (Edited)
Looking at the specs of the sandwhich plate, Will it fit our car?
Overall Size
3.15" x 2.8" x 1.11"
It does not say anything about thread. And thats what im really concerned with atm because of my current leaking sandwhich plate.
You need the 20 mm thread. It sounds like you may have the 3/4"-16 thread on your leaker.
You can put a 20mm filter on a 3/4" base but not a 3/4" filter on a 20mm base. The 20 mm will screw on and tighten somewhat.
Discussion Starter · #14 ·
I know it needs to be 20mm. What i mean is it does not say the thread size on this
Oil Sandwich Plate, Silver, by Mishimoto
Which is the one that comes in the oil cooler kit with the 2 1/8" NPT Ports
and M20 x 1.5" Ports.
BTW thanks for all your help RED. I really Appreciate it
What I was saying is you may have a 3/4x16 on your car now and that is why it leaks.
If you are asking about the hose fitting thread I suppose it is whatever comes with the kit. 3/8" NPT x 1/2" hose is what my adapter has.
But looking at their accessories the an adapter fitting is 20mm.
http://www.mishimoto.com/sandwich-plate-fitting-m20-x-10an.html
Sandwich Plate Fitting M20 x -10AN, by Mishimoto
Lol i think where missing what each other is saying :)
Im more worried right now about if the sandwhich plate i listed will fit the car with no leaks. I dont believe my leaks are coming from the adaptors on my car ATM
Well what thread are you talking about?
There is an adapter nipple that you use to mount the cooler adapter. This would need to be 20 mm female for the engine side and 20 mm male for the filter side.
What can happen is you may have an adapter nipple on there that is 20 mm female and 3/4-16 male on the filter side. This may be why your filter is leaking.
As far as the kit you need to ask them what the thread is for the adapters. With the adapter I have it came with 5 different adapter nipples.
Discussion Starter · #18 ·
I had it looked at to see if we could find where the leak was, And they suggested getting new O rings, but where not sure what size i needed. Would you happen to know?
You need to take the O ring off and go shopping. If there is a Motion Industry outlet near you they have all kinds of O rings that you can get individually.
But if I was taking the filter off I would get a cheap filter that has 3/4 " x 16 threads and see if it threads on. If it does it has the wrong thread adapter on it.
About any pre 2000 Ford or Chrysler engine uses that thread.
Discussion Starter · #20 ·
Quick update. I went with the glowshit and have not seen any oil spots. Its been on for about a week now.
1 - 20 of 20 Posts
