21 - 26 of 26 Posts
· I'd rather do it myself
I have a manual temp control for the coolant temp. I just have it run on the hi speed. The low speed I pulled the relay out.
Here's my post on it. You do not have to open the fuse box I have found out. And it is also a good time to add an LED for an indicator along with a switch if you ever want to manually kick it in. All done with a small ground wire to the high speed fan relay coil.
I've gone through 4 thermostats over the years. The original one, two OE replacements and one Motorad which I currently have. Only the original and the Motorad run at 180F like they should. Both Hyundai replacement ones I got ran at 185-187F.
21 - 26 of 26 Posts
